08-22-2012, 03:46 PM | #1 |
Rep 72
Macht Schnell Stage 2 intake installed today
Well,
The video showed 5 minutes, but it took me around 2 hours. I would get it 90% done and then find out that something or other wouldn't fit together so I would take it all back apart and start over. In the end I got it, but the fit is not perfect. The whole system doesn't line up quite right with the airbox so the system is placing torque on the lid which causes a small amount of separation between the lid and the box in the area around the connection. Does anyone think this will be an issue? My biggest concern would be heat soak offsetting the marginal gains this system offers. The box is sealed all the way around the edge except for a small opening around 3 inches in front and behind where the filter portion meets the box. It also causes a gap in the upper and lower portion of the box where it forms an opening to meet with the snorkel, but the rubber portion of the snorkel covers most of it. Could it be a fitment issue with the 2012 e92's? Or maybe it is just the nature of the beast. I like the sound, but am considering selling this kit off because it doesn't fit my car 100%. Thanks, -Bob |
08-22-2012, 04:18 PM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
That sucks to hear. I didn't have any big fitment issues on my 2012. Maybe some further adjustments are needed?
08-22-2012, 04:20 PM | #3 | |
548
Rep 5,695
There should be no openings or gaps when installed properly. |
08-22-2012, 04:28 PM | #4 |
Rep 72
I'm not sure. I tried EVERYTHING to get it to work properly. The whole setup by itself lines up really nice, it's just the angle and pressure in which it enters the airbox that is the issue. Part of it is the pressure put on by the filter "button," the spring loaded part that pushes on the front of the filter. It alone is enough to distort the box with just the filter installed.
08-22-2012, 04:31 PM | #5 | |
548
Rep 5,695
08-22-2012, 06:50 PM | #7 |
Rep 17
Like the OP I had the same experience on my 2012 M3, I had exactly the same problem in the same area when I installed mine last weekend. I will definitely try cutting down the spring, any recommendatrion of how much to cut off? Definetly not happy with the fitment and not what I expected after spending $500 on this upgrade.
08-22-2012, 07:02 PM | #8 | |
548
Rep 5,695
08-22-2012, 08:07 PM | #9 | |
Rep 2,940
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
08-24-2012, 04:28 AM | #10 |
168
Rep 1,792
I have the same little gap as the OP, will EAS be able to re-adjust mine free of charge?
Also, why is the air filter spring needed when the filter is hose clamped to the plastic plumbing pieces? |
08-24-2012, 11:53 AM | #11 |
548
Rep 5,695
We would be happy to inspect it for you. Please contact us to schedule an appointment.
08-24-2012, 01:53 PM | #12 |
Rep 72
08-24-2012, 02:49 PM | #13 |
168
Rep 1,792
Also, to make sure the system is sealed 100%, I use a thread/pipe tape on the threads of the screw-in PVC plastic fitting for an air tight seal.
I recently did an oil analysis, and no silicon issue was found in my sample. I'll have to say, as far as filtration goes, MS stage 2 intake is 100%. |
08-24-2012, 11:58 PM | #14 |
515
Rep 1,705
To speak on behalf on my own experiences, I would like to add some input to this thread. I bought and installed my MS Stage 2 Kit about a month ago. At first I installed the plastic pipes and saved the filter for last. I watched the youtube video again and decided to start with mounting the filter into the box FIRST.
- On a side note, my MS Stage 2 Kit came with a smaller plastic pin to hold the filter into place. Once the filter was fitted into the box WITHOUT the plastic piping connected the filter fit snugly in the box. I then installed the plastic piping along with the clamps. The noise added is great, and I def. felt some more power. Could this kit have been cheaper? I think so, but I'm happy with my purchase
08-25-2012, 12:04 AM | #15 |
127
Rep 6,773
08-25-2012, 09:35 AM | #16 |
Rep 72
I searched the crap out of it before I bought this intake, and found numerous threads with dyno's on THIS FORUM saying that the intake produces a sold 10+ HP, which is why I bought it. They were all wrong and I wasted money? If that's the case it leaves a bad taste in my mouth.
08-25-2012, 12:37 PM | #17 |
Rep 2,400
Very good to know, as this was my key worry about using an oiled filter...thanks for sharing this real world experience. Also, in my research, I found out that the OEM paper filter has 99.1% filtration efficiency per ISO tests, which isn't much better vs MS.
08-25-2012, 12:43 PM | #18 | |
Rep 2,400
Seems like 7+ hp for elbow and filter is corroborated by numerous dynos (even away from MS/EAS). Even the Dinan intake (similar design) is +7 hp, and Dinan is very conservative w/ their advertised HP gains. While one can argue it is within the "margin of error", outside of some tests of AFE products, no MS filter/intake elbow shows a loss of power (at least I haven't come across any) on Dyno tests.
08-25-2012, 10:14 PM | #19 |
168
Rep 1,792
My car was dynoed at 357wrhp with MS stage 2 intake and an Akra slip-on on a 104F day. Don't really have a baseline to verify any gains, but my number is definitely strong after I compare my result against the dyno database with similar dynojet runs.
08-27-2012, 05:35 AM | #20 | |
Rep 4,001
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
