08-23-2012, 10:05 PM | #1 | |
Troll
79
Rep 1,193
Tyre Pressures
Hi guys,
Just wondering what pressures you guys run front/rear. Cheers
BMW E92 M3 Coupe | Jerez Black | Fox Red Extended / Carbon Black Trim| Fully Loaded | Moonroof | 6MT | Gintani Sport Quote:
08-24-2012, 01:49 AM | #2 |
10
Rep 362
I don't own an M3 but a general rule with tyre pressures that i have found is to start at what the manufacturer recommends then increase/decrease 2psi at a time to find the tyre pressure/steering feel that you are happy with. I guess what i am trying to get across is that there are no hard and fast rules as to what pressure you should run for daily/street driving as long as you don't stray too far from what the factory recommends for your tyre/rim size.
I personally like a "heavier" steering feel so I run Front: 40psi (235/35/R19) and Rear:42psi (255/30/R19). |
08-24-2012, 06:40 PM | #3 |
Rep 1,464
Drives: BMW X5M Comp
08-24-2012, 09:12 PM | #4 | |
Troll
79
Rep 1,193
Suh-weet. I've been running the same front/rear around 40 psi I think.. Would yours be same for good old fashioned air?
08-24-2012, 10:19 PM | #5 |
Rep 1,464
Sure, just the same. It's the higher recommender pressure on the tyre placard. Rears on mine are a different size to stock (295x30x19) but I've always run the same pressure (air or nitrogen) and been happy with the results.
