      09-03-2012, 05:54 AM   #1
ExREX
ExREX's Avatar
Australia
12
Drives: 135i & x3 30d
OT: Wi Fi Network with multiple access points
Can anyone recommend someone to help me set up my wifi network with multiple access points (joint by existing ethernet cable)?
      09-03-2012, 06:13 AM   #2
dazza_
Drives: 2008 LeMans Blue 135i
When you have Multiple AP's set the SSID as the same value on all AP's.
If using the 2.4GHz band set your AP's to use channels 1, 6 and 11 as they are the only 3 non overlapping channels. If using 5GHz use channels 36, 40, 44, 48, 52, 56, 60, and 64.
A couple of pic's always helps:
If the AP's are connecting back to a switch where you have wired clients connecting to then it should be pretty straight forward, DHCP should give them necessary IP/DNS settings.
      09-03-2012, 06:14 AM   #3
Lardman
Australia
Drives: f80 m3
What kind of devices? Easiest thing to do if you have an old router is disable the DHCP (automatic address assignment) and set up a 2nd wireless network with the same passwords. Your devices should generally switch to whichever network has the stronger signal.
If you do that, make sure you plug the ethernet cable into the switch ports and not the internet one on the 2nd router!
      09-03-2012, 05:34 PM   #4
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
in a perfect world, but each manufacture has different thresholds of signal quality before they jump to another signal.
what devices are you planning on using? how many clients do you have and what type of clients? 802.11a/b/g/n?
what type of switch do you have? integrated router/modem,Managed/non-managed, 100mb or Gigabit?
what router do you have?
what is issuing DHCP on your network?
  1. connect all access points to switch via network cable. I generally give my infrastructure devices fixed IP addresses.
  2. Configure your router or switch as a DHCP server.
  3. configure wireless SSID and security the same on all access points
  4. configure wireless channels as stated above by Dazza.
  5. test.
Example;
Router<----------->Network Switch<------------>Access Points
or
Router/integrated network switch<------------>Access Points
Router acts as DHCP Server - IP Address 192.168.0.1/255.255.255.0
Switch - IP Address 192.168.0.2/255.255.255.0
Access Point #1 - IP Address 192.168.0.3/255.255.255.0
Access Point #2 - IP Address 192.168.0.4/255.255.255.0
DHCP Scope range - 192.168.0.10 - 192.168.0.254
mask - 255.255.255.0
Default Gateway - 192.168.0.1
DNS - 192.168.0.1
Hope this helps.
      09-03-2012, 06:58 PM   #5
garrathj
Australia
Drives: 2008 135i
2008 BMW 135i  [0.00]
I found this helpful when I did mine a couple of weeks back.
http://www.hanselman.com/blog/Config...eeRoaming.aspx
      09-03-2012, 07:04 PM   #6
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
Faaaarrrrkkk and to think I got a headache from trying to read the meth install docs, this is puting me into a coma.
      09-03-2012, 07:39 PM   #7
ReyT
Drives: BMW
hang on aren't you in the information system industry
      09-03-2012, 07:46 PM   #8
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
have you seen dilbert
      09-03-2012, 07:54 PM   #9
ReyT
Drives: BMW
      09-06-2012, 10:27 AM   #10
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
Get one of these:
And a bunch of these:
The Controller is about $1300 and the APs are about $12,000 for a pack of 10.
... Just kidding.... but it would solve your problems
      09-06-2012, 05:05 PM   #11
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
not really, he'd still need a POE switch to plug em into!
      09-06-2012, 07:17 PM   #12
ReyT
Drives: BMW
holy moly you are alive!
btw we have those cisco AP at work and they are awesome
      09-06-2012, 08:26 PM   #13
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
Yeah... I live... Been ridiculously busy at work... I notice that you did a bad thing and as a result, have a new account
      09-06-2012, 08:32 PM   #14
dontask
Australia
13
Drives: White BMW 135i
For a home network, its pretty simple to buy some cheap Cisco routers, flash them with DD-WRT, then run them in bridged mode. You won't even need to connect them via an ethernet cable.
Step 1) Buy 2 x DD-WRT compatible routers. Possible: http://www.umart.com.au/newindex2.phtml?bid=2
Step 2) Flash with DD-WRT. www.dd-wrt.com
Step 3) Setup wireless bridging: http://www.dd-wrt.com/wiki/index.php/Wireless_Bridge
Modded 135i
RHD Bumblebee
      09-06-2012, 08:43 PM   #15
mcmn
Drives: MY10 AW 135i
dontask +1
I'd get the TPLINK TL-WDR4300 N750 $109 bucks on ebay.
      09-06-2012, 09:34 PM   #16
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
808
Drives: a black car
Originally Posted by mcmn View Post
dontask +1
OT: but paul do you want this OCC ?
      09-06-2012, 09:36 PM   #17
ExREX
ExREX's Avatar
Australia
12
All good technical wisdom but i think i need someone to do this for me. Anyone have a tech person they recomment to set up for me?
      09-06-2012, 09:48 PM   #18
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
sounds pretty simple to me, shit there's even pictures to follow. Come on dude give it a crack, whats the worst that could happen
      09-06-2012, 10:35 PM   #19
mcmn
YES!!! Sorry I completely forgot - when can I pick it up? Can I paypal you?
      09-06-2012, 10:35 PM   #20
mcmn
Where do you live in sydney?
      09-07-2012, 05:52 PM   #21
ExREX
ExREX's Avatar
Australia
12
lower north shore
1addicts
