BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      09-13-2012, 07:34 PM   #1
rvaM3
rvaM3's Avatar
Drives: 2011 M3
Battery Stabilizer
Where would one, locally, buy a battery stabilizer required for ECU tunes for the E92 M3?
Thanks in advance
      09-13-2012, 09:08 PM   #2
rvaM3
rvaM3's Avatar
Drives: 2011 M3
Search, you dummy!!!!
      09-13-2012, 10:44 PM   #3
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
If you want local help, you should post in the local section.
      09-13-2012, 11:10 PM   #4
JeffreMarti
Drives: audi
      09-16-2012, 02:23 AM   #5
BPMSport
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
No need for a stabilizer. The read will take 36 minutes with my cable, it will read the ECU even at a low voltage. Most cars have no problem.
Programming back the tuned file only takes under 5 minutes
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      09-16-2012, 06:25 AM   #6
armyav8tor
n1smo
armyav8tor's Avatar
Drives: E92 M3
Just get a battery tender.
      09-16-2012, 02:42 PM   #7
THE TECH
THE TECH's Avatar
307
That won't satisfy the battery voltage needs when doing long programming sessions.
      09-16-2012, 03:27 PM   #8
C|3R1C
So Kewl Guy
C|3R1C's Avatar
49
Drives: 2010 E93 M3 DCT
I got a battery charger at autozone for like 30 bucks. Charges at 2,8 and 12 amp increments. I usually use 8 amps.
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
      09-17-2012, 08:09 AM   #9
THE TECH
THE TECH's Avatar
307
FYI, for reprogramming or doing factory updates on the car as the OP asked, this will not work.
      09-17-2012, 11:52 AM   #10
C|3R1C
So Kewl Guy
C|3R1C's Avatar
49
It worked on my friends 335. His battery died during flashing and left a part of the ecu blank. This was before the charger. (my battery never died so I can't comment on my car lol). Turned up the charger to 8 amps and it worked.
If this isn't OPs question then my bad lol. I guess I was understanding it wrong. And if I'm mixing up what I have with a charger then my mistake again lol
      09-17-2012, 11:57 AM   #11
THE TECH
THE TECH's Avatar
307
The issue is that when programming, the ECM requires precise voltage or it will stop programming. Most battery chargers or tenders will not provide a stable amount of voltage. For lengthy programming, it's not safe to use anything but a voltage stabilizer.
      11-07-2012, 09:00 AM   #12
KmndntKlink
KmndntKlink's Avatar
21
Drives: 2010 e92 m3
So what exactly do I need for programming/update to 240e sessions? I've borrowed a charger that can do 13v and 15amps. That should be enough no?
E92 ///M3 in Dakar Yellow, M-DCT, iDrive, 220M OEM rims, Active Autowerke Green filter, Turner Motorsport test pipes, BPM stage 2 tune, Stoptech ST-40 F+R in yellow.
      11-15-2012, 07:23 AM   #13
edwinm3
edwinm3's Avatar
Drives: F82
I ask the same
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
      11-15-2012, 08:41 AM   #14
THE TECH
THE TECH's Avatar
307
Originally Posted by edwinm3 View Post
I ask the same
For just an update to 240E and no other module updates, you shouldn't need a charger at all.
m3post
