      10-02-2012, 11:33 AM   #1
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
DINAN Exhaust Now Available for the 1M!
Just got the latest newsletter from DINAN last night. The welds, construction, design and price are spot on! Also available in ceramic black tips. I had the DINAN exhaust on my E90M3 and was extremely happy with it. This exhaust looks promising and thought I would share.
http://www.dinancars.com/shop/index....eries-M#page=1
Product Description
Dinan's free flow exhaust for the 1 Series M is sporty, just as it should be. Improving exhaust flow and adding a great sporty sound that is aggressive under hard acceleration with less drone than stock. Improve performance by 6 horsepower and 5 ft-lbs of torque. 100% 20 gauge-304 stainless steel construction to resist corrosion for years to come. Built with exacting specifications to ensure that the system fits correctly using the factory hangers . Designed to provide maximum flow while keeping things civilized with the Hemholtz chamber design. The design features quad 3.25" ceramic black or polished aluminum tips for a tasteful high performance look.
Benefits of the Free Flow Exhaust:
+ Built specifically for the BMW 1 Series M
+ Less "drone" than stock
+ Enjoyably louder
+ Sportier Sound
+ 100% stainless steel construction
+ Bolt-on installation using high quality BMW OEM clamps
+ Quad 3.25" laser engraved exhaust tips
+ 6 HP @ 6600 RPM, 5 FT-LB @ 6600 RPM
+ Hemholtz chamber to remove drone
+ Tilger mount bracket to reduce vibration and improve longevity
Dinan Performance Exhaust FAQ
Does a louder exhaust make more power?
Not necessarily. A freer flowing exhaust makes more power by removing friction in the exhaust system but how loud an exhaust is has to do with its packing material and or routing. It is possible for a loud exhaust to actually make less power than a stock exhaust. The best exhaust is the one that is the freest flowing and has a noise level that you enjoy.
What makes an exhaust "hummm" under light throttle?
This sound is commonly called "drone". It is caused by resonance in the exhaust system and can quickly give you a headache. Drone is the toughest characteristic to remove from an exhaust system. The use of a "hemholtz" chamber to work as a noise canceling device is a great option along with the use of butterfly valves when needed.
How are Dinan exhausts made?
All Dinan exhausts are designed and hand built in California at the Dinan Headquarters. They are welded by hand using precise tools to ensue perfect fit. All are built from 20 gauge-304 stainless steel for strength and corrosion resistance.
Does the kind of steel used matter?
Yes. Your cars exhaust is subjected to the elements and other harsh conditions that occur under a car. The exhaust gets hit with gravel, salt, water, sand and whatever else is on the road. Using high quality stainless steel keeps corrosion at bay in this tough environment.
      10-02-2012, 11:40 AM   #2
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
You missed the recent thread on the exhaust section then, here:
http://www.1addicts.com/forums/showthread.php?t=751559
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      10-02-2012, 11:47 AM   #3
mPlasticDesign
684
Whoops, sorry, I did. It was posted over the weekend and I think a lot of people might miss it as well if it's in the subforums instead of the general section. Besides I'm not selling it. Mods can delete if they don't want exhaust discussion outside the subforum section.
      10-02-2012, 12:20 PM   #4
Redadair
Redadair's Avatar
Drives: 2011 1M #293 - 88 E30 M3
Thanks for posting, I rarely look in the subforums and would have missed it.
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740)
88 E30 M3 100% OEM 73K Miles
02 E39 M5 Le Mans Blue 50K Miles
06 E46 M3 ZCP 58K Miles
      10-02-2012, 08:39 PM   #5
mattm
mattm's Avatar
Drives:
I wish they would give a weight or weight difference from the OEM exhaust. I'll email them and see if they know.
Matt Murray
I am perfectly capable of learning from my mistakes. I will surely learn a great deal today.
      10-03-2012, 10:44 AM   #6
mattm
mattm's Avatar
Drives:
I received the following this morning, from Dinan:
The weight is virtually identical. Dramatically “cooler” exhaust note and a bit less drone running at highway speeds. No “valves” on our system, improving flow at all throttle settings. One of the best sounding exhausts we have ever produced!
Scott
Matt Murray
      10-03-2012, 11:07 AM   #7
mPlasticDesign
684
Scott
I have no doubt it will sound great, but the fact that it is not a true bolt on system that requires cutting the OEM exhaust might be a deal breaker for many. My Eisenman sport system included a connecting pipe that would bolt right up to the stock mid pipe. When I decided to go back to the OEM exhaust, the swap was a breeze.
      10-03-2012, 11:42 AM   #8
mattm
mattm's Avatar
Drives:
As I replied to Scott, I don't care about the drone, I want to reduce the weight of the car (a high 3,200 pound pig). As to fix the drone I told him I turn the radio up.
Matt Murray
      10-03-2012, 08:28 PM   #9
///M1
///M1's Avatar
Drives: Many
Is there any update on their CF CAI? Last I spoke to them they were supposed to release it 'around the same time as the exhaust'.
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      10-03-2012, 08:59 PM   #10
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
It needs to shed weight, but not from the rear.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      10-03-2012, 09:07 PM   #11
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
I forgot to ask about the CAI, but he did mention that they will be releasing the stage 3 package before the end of the month which is comprised of a tune, FMIC, and oil cooler. The only way to get the warranty is to buy the entire package.
2017 F80 M3/AW
      10-03-2012, 09:14 PM   #12
///M1
///M1's Avatar
Drives: Many
Yeah, sadly Dinan is like that, to get their warranty you cannot mix and match with other tuners/products
      10-12-2012, 11:43 AM   #13
4thM3
4thM3's Avatar
Drives: 2020 M2 Comp. Alp. White
Was at DINAN this past Monday. All 1M products (CAI, FMIC, oil cooler, exhaust, stage 2 & 3 software, etc.) are now available. They are also in development on some suspension components as well. Beautiful stuff.
1addicts
