BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      10-11-2012, 02:45 PM   #1
happyg512
Drives: E93 M3, E36 M3
Your thoughts and feedback – catless X-pipe with resonators (4)
I thought the post can help me form a better decision on the modifications I am thinking about.
First my goals are
  • To get to the same horsepower to weight ratio as the coupe (yeah I have a convertible)
  • If I go catless, I would like to be able to easily change and go back to stock (complete bolt-on, no cutting, welding or fabricating and I need to be able to use any 'cat-back' or rear muffler sections after the resonators) in case I need to do it for inspection.
Based on my calculations (assuming a 15% delta between CHP and WHP) I will need to aim for at 410 WHP and I would like to stay NA if possible.
The improvements I am currently thinking off are
  • Air filter (probably BMC race) – still need to check whether I have the restrictive stock filter.
  • Dynamic air scoops (either RPI, aFe, etc…)
  • Pulley (probably Macht Schnell)
  • Primary and secondary cat delete (either Borla X-Pipe with test pipes and 4 resonators, Dinan High Flow Middle Racing Exhaust or Gintani E9X M3 X Pipe)
  • Tune 93 Octane
  • In the future I might go with new mufflers (looking at weight savings; titanium, but this will be pricey); either Akrapovic Slip-On or Remus.
So my questions now are
  • Can I use the stock OEM muffler with all of the listed X-pipes?
  • Was someone able to do this complete bolt-on, no cutting, welding or fabricating and any 'cat-back' or rear muffler sections after the resonators?
  • If yes, would it be possible to get sound clips? – assuming nobody lives in the area so I can listen to these combinations.
Feedback and opinions are welcome.
Thanks for reading,
Guenther
      10-11-2012, 03:49 PM   #2
Wolfinwolfsclothing
37
Drives: E92 ///M3 Coupe
Honestly, for the price youre better off going with a supercharger especially if you intend on doing akra plus an x pipe which will easily tally 5K whereas you can do a new supercharger for ~8K.
      10-11-2012, 03:59 PM   #3
happyg512
Yes, thanks, I thought about this option too.
My main concern is my current understanding that superchargers are not street legal in California, so I am currently assuming that I will have a problem with inspection in Massachusetts as well. I think the regulations are the same.
So for me - changing the X-pipe and the tune to get an inspection is just a lot less work than with a supercharger.
      10-12-2012, 05:19 AM   #4
drifts500
drifts500's Avatar
South Korea
10
Drives: e92 m3
You really care...about street legal tune in So Cal??
Catless X-pipe is not street legal. Tint is not legal in CA. Tune to 93 octane also..I believe...
For the exhaust..if you do not want to spend a lot of money..
Buy Macht Schnell test pipe ($500) and do OEM mod ($200)....
If you delete resonators, you would get raspy
09 e92 M3 Coupe
TE37RT with Hankook R-S3 265/285
Techtec ECU
Stock Exhaust
      10-12-2012, 01:43 PM   #5
happyg512
No, sorry my mistake for not providing enough details.
I am currently "trying" to use the Cal rules, because it is my impression - what passes inspection in Cal will also pass in MA. I am sorry I don't know the exact differences between MA and Cal, meaning what will not pass in Cal but will pass in MA. So I kind of go a safer route at the moment.
      10-12-2012, 02:53 PM   #6
SflBimmer8484
SflBimmer8484's Avatar
1469
Drives: .
Bolt-on's are a great place to start when trying to unleash the maximum amount of Horsepower from your S65 engine. With our full Bolt on N/A system our customers have achieved excellent numbers (398 whp) above the stock (350 whp).
Our Kit consists of the following
AA- Axle Back Exhaust System
AA-X-Pipe Catless
AA-Power Pulley Kit
AA-Green Filter
AA- Tuning Software
      10-12-2012, 02:56 PM   #7
atermechi
atermechi's Avatar
Drives: e92 m3 MR
have you done the OEM mod with the test pipe? I havent been able to find someone with this set up any were. please let me know
      10-12-2012, 03:02 PM   #8
happyg512
Have you done the OEM mod with the test pipe?
No I have not and I am not sure whether this is a good idea, because of the sound effects.
There is also a separate thread called “OEM mod + Catless” on this subject it think.
      10-12-2012, 03:03 PM   #9
happyg512
With our full Bolt on N/A system we got 398 Whp
That sounds great.
Could you also please be so kind and help me understand whether this will pass MA state inspection? I really would like to be sure before I make my decisions.
      10-12-2012, 03:12 PM   #10
SflBimmer8484
1469
Drives: .
That sounds great.
You can and here is how!
Option A.We also have a special software to pass obdII testing with catless xpipes but this will not work if you have a sniffer test in your state.
Option B. Stubbies http://www.m3post.com/forums/showthr...rke+emmissions
m3post
