BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
Mporium BMW
      10-20-2012, 01:19 AM   #1
forced03
Drives: M3
Remove Delete-R before warrenty work?
Hey-
I have an appointment for a few issues and wondering if I should remove delete-r before dropping off.
Issues are unrelated to mods which are only akra evo + delete-r.
Issues:
Started with vibration under braking
DCT is starting to feel sloppy..
On tight corners (90 degree) now getting lots of noise/vibration (initially thought from rear end/binding but now not so sure)
Thought I had warped/cracked rotors but maybe bearing or ???
Should I remove delete-r? I'd like the updated software (have a 2011) while its in and planning on taking tech on a test drive to replicate issues...
      10-20-2012, 01:43 AM   #2
BMW Fanatic
135
Drives: slow
What's you relationship like with the dealer? Some won't care about it, while others might. + it's not a tune so regardless it won't be overwritten by them.
      10-20-2012, 10:32 AM   #3
forced03
Drives: M3
I've only had my car in once before so no relationship. They can update the software with the delete-r in place, right?
      10-22-2012, 09:02 AM   #4
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
I would just remove when you drop it off.
      10-23-2012, 11:16 PM   #5
forced03
Drives: M3
They denied the update since no codes and couldn't replicate any issues. They did however replace front rotors and pads due to vibration caused by uneven rotor thickness
Now looking for best Akra Evo tune!
      10-23-2012, 11:18 PM   #6
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
dude thats lucky i had major uneven front wear and vibration and they denied replacing mine.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
m3post
