01-30-2013, 12:51 AM | #1 |
BEASTIE
Rep 39
Meisterschaft Exhaust Combo's
Hi.
What sort of combinations are you guys running with your Meisterschaft axle back exhausts. I currently have the N55 mids hooked up to the Meisterschaft axle back.. Have put about 5K kms on them.. The drone around 2K to 2.3K seems to be just getting worse and worse. Was considering fitting 2 inline resonators to the N55"s to help eliminate the drone, although it might quieten the exhaust note a bit too much.. Any recommendations would be greatly appreciated, as I love my Meisterschaft.. PS... Still running the OEM DP's. Last edited by Meijo; 01-30-2013 at 12:58 AM.. |
01-30-2013, 01:58 AM | #2 |
Rep 249
I think we all have the same problem. I only get it on 6 gear around 72-75mpg. I have learned to live with it for the past 2 years.
I also have stock DP and a friend with AR DP, has the same problem. |
01-30-2013, 10:06 AM | #3 |
24
Rep 391
I have the Berk mid and Meisterschaft and it is REALLY bad. I just ordered the N55 mid which should help some but I am still expecting drone. With the Berk the drone is so bad in 6th that even the stereo won't drown it out.
Current - 2015 Cayman GTS White Borla Exhaust
Prev - AW 1M #43 USA Meisterschaft, N55 mids, AFE CAI, ER Charge, Wagner IC |
01-30-2013, 12:16 PM | #4 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
get yourself in higher rpm and lower gear to make the drone go away otherwise yes, you have to live with it, ive had all combos of stock dps, stock midpipes, n55 midpipes, AR downpipes and meisterschaft section 1 straight midpipes, the drone is there at different levels. best way to combat it is again, lower gear and it goes away
01-30-2013, 05:16 PM | #6 | |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
You probably have no drone because you have a stock catback. Everyone also has different tolerances for drone and depending on ones driving style, some may experience it more than others. I personally accept that drone is usually unavoidable to some extent with the more aggressive aftermarket exhausts. |
01-30-2013, 06:01 PM | #7 | ||
BEASTIE
Rep 39
To clarify.. I had the N55 mids on initially, with drone between the 2K -2.3K rev range at all speeds. Replaced the N55's last week with the OEM mids and the drone is still present, in the same rev range, although slightly more muted. Only thing is, with the OEM mids, I have lost engine responsivness down low and their is now lag in the low rev range, due to the two mid cats. Was planning on having 2 resonators fitted to the N55's to hopefully reduce or eliminate drone. Was hoping someone has already tried this, and can give some sort of positive feedback. |
01-30-2013, 09:37 PM | #8 |
24
Rep 391
I can live with the drone I am getting but if I can lessen it some that would be good. However, I'll gladly deal with it for the WOT sound that this exhaust produces!
I haven't tried this but there was a thread somewhere on the board about packing the compartment in the trunk with towels or something. I seem to remember some saying that it reduced the drone. But I think in cars with the HK stereo there is a amp there that needs space to keep cool? I'm not completely sure though because I haven't raise the full panel beyond the battery area.
01-30-2013, 09:53 PM | #9 | |
BEASTIE
Rep 39
What mid pipes are you running mate? |
01-30-2013, 10:04 PM | #10 | |
Rep 3,070
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
01-31-2013, 03:46 AM | #12 |
BEASTIE
Rep 39
01-31-2013, 05:26 AM | #13 | |
Moderator
29419
Rep 13,107
Also reported in the issues log: http://www.1addicts.com/forums/showp...27&postcount=1
///M is art ↔ Artemis
01-31-2013, 07:52 AM | #14 |
56
Rep 348
I have the Eisenmann race and n55. Drone is minimal. My problem was a resonance and rattle around 2k-2.5k rpm. I layed down a sheet of dynamat and a layer of carpet pad in the open section of the trunk and it really helped. Less drone and less rattle. Also less exhaust note
01-31-2013, 11:04 AM | #15 | |
24
Rep 391
Miesterschaft axel back I knew it would be loud and that there would be drone, so don't get me wrong. I am not about it, but if I can change the drone from occuring at 2500-2700 RMP down to 2100-2300 RPM it would make a wold of difference to me and my style of driving. And if not, I'll spend a little more on gas and run in a lower gear
01-31-2013, 09:11 PM | #16 |
BEASTIE
Rep 39
Thanks again for the replies...
Looks like we all have some sort of drone with the Meisterschaft... So will re install the N55 mids tomorrow morning.. Meanwhile... I will rubber line the hollowed out boot/trunk compartment tonight, to reduce drone. I am using 3mm Everroll sound deadening flooring rubber.. We use this in our Spin/Cycle room, at out fitness centre to reduce accoustic booming from the sound system.. Fingers crossed.. Last edited by Meijo; 01-31-2013 at 09:20 PM.. |
02-01-2013, 10:00 AM | #17 |
Rep 6,478
The maddads have resonators IIRC? If so that'll help a ton, adding Berk mids to my setup more or less got rid of 6th gear cruising drone. The muffler for the 1m is obviously a bit different, but the general sound/tone is going to be very similar coming from an N54.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
02-13-2013, 08:58 PM | #18 | |
BEASTIE
Rep 39
Even rubber lined the battery compartment to eliminate resonating in the open spaces.. Made NO DIFFERENCE to the drone.. Infact, the drone lasts over a broader rev range with the OEM mids installed than when I had the N55 mids installed.. go figure. |
02-13-2013, 09:51 PM | #19 | |
Rep 3,070
02-13-2013, 09:57 PM | #20 |
BEASTIE
Rep 39
03-02-2013, 05:52 AM | #21 |
Rep 110
I have the axle back exhaust paired with Supersprint DeCatted front and non-resonated center exhaust.. and its just beautifully LOUD !!
On another note.. I have noticed my right two exhaust pipes become dirtier faster, than the two on the left. Does anyone else have this? |
03-02-2013, 09:01 AM | #22 | |
Rep 3,070
