      03-29-2013, 11:52 AM   #1
p66
56
Drives: 1M
Help with strange sound from transmission
I am starting to get a noticebly louder sound from what I think is the transmission. When the car is stopped and in neutral, I can hear a faint rattle or whirring sound. Frankly, it sounds like a helicopter. When I depress the clutch the sound stops. Release the clutch and the helicopter is in my trunk again. It's faint, so I can't tell if it's still present when in gear and driving. Any ideas?
      03-29-2013, 12:05 PM   #2
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
How loud is it?
I am thinking dual mass flywheel chatter, but that shouldn't be very loud.
      03-29-2013, 12:17 PM   #3
p66
56
Drives: 1M
noise if faint, but I never noticed it before so I'm sure it's a new issue. I'm pretty sensitive to the noises my car makes. I can only hear with radio off. Still faint.
      03-29-2013, 12:24 PM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
That sound is normal for BMW's with a manual transmision. Its the dual mass flywheel flexing and dampening the vibrations.
I would say "the sound" is more like that of a bunch of marbles in a metal coffee can. As long as the noise goes away when you step on the clutch - this noise is normal.
If you turn off the engine you will also hear the flywheel make some noises as the rpms slow to nil. IF you depress the clutch while switching off the engine, you won't hear that noise. I also turn off the engine with the clutch pedal depressed.
      03-29-2013, 12:39 PM   #5
p66
56
Drives: 1M
By marbles in a coffee can, do you mean swirling the marbles around in a circular pattern, rather than shaking the can? I think the sound I'm hearing could very well match the sound of marbles being swirled in a can. Stirred not shaken! Bond would be mortified.
      03-29-2013, 12:53 PM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
...do you mean swirling the marbles around in a circular pattern..
Yes, that is the sound. It is normal.
Sometimes changing the trans oil might change the noise a bit. Sometimes not. Its really not harming anything inside the trans though.
Still... you might have your dealer listen to your trans noise - see what they think.
      03-29-2013, 01:09 PM   #7
p66
56
Drives: 1M
Thanks. I'll add to the very short list of items next time I make it to the dealer.
      03-29-2013, 03:55 PM   #8
ayao
Thread killer
643
Drives: 1M
Mine makes this sound.
      05-01-2013, 10:46 AM   #9
Pankrivoklat
Pankrivoklat's Avatar
Czech_Republic
34
Drives: BMW, Porsche
My car produces exactly the same noise...
2019 BMW F90 M5 | 2014 Porsche 991 Carrera 2S | 2013 BMW F01 740dX | 2011 BMW E82 1M Coupe | 2008 BMW E70 X5 3.0d | 2003 BMW E46 M3 Coupe | 2000 Porsche 996 Carrera 4 | 2000 BMW E39 535i | 1998 BMW E39 528i
      05-02-2013, 01:03 AM   #10
Zuzu
Zuzu's Avatar
Australia
2816
Drives: M2C HS 6MT
Originally Posted by Ian///M View Post
Normal... Both my 1M and 135i made this noise
+1.. Both my 135i and 1M have this chatter.. Like Dackle, I always depress the clutch pedal before turning engine off.
1addicts
