M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      05-08-2013, 08:23 PM   #1
utmiken
Drives: F10 M5
Anyone with H&R and alignment issues?
I've had the H&R springs installed for a few months now. Car drives great and haven't had any apparent issues. The car was aligned right after the install.
With the springs installed should alignment be all within BMW spec?
All my numbers are within spec EXCEPT front camber. It is slightly negative but I have yet to see any uneven wear on the fronts. Alignment guy could not figure out how to adjust front camber.
Is the front camber adjustable?
I hope the shop guys can clear this up for me as mine was the first F10 M5 suspension my shop had worked on.
      05-08-2013, 09:10 PM   #2
nv6425
Drives: X7 Dark Shadow
Was this done at Motorwerks?? I had mine done last week and they did my alignment immediately and it's pulling right and I have a steering vibration at 85+ MPH. I'm guessing I need to have it realigned, when I do, I will find out about the camber on the front.
///M
      05-08-2013, 09:22 PM   #3
utmiken
Drives: F10 M5
Not Motorwerks for me but I hear the've done quite a few M5's already. I don't want to call out my shop until I get more info.
I've had no issues with vibrations, pulling, or uneven wear and that's with about 2000 miles put on it since the install. I'm just concerned since front camber is out of spec and if a little negative camber is worth the concern.
I'm -1.3 on the fronts btw
      05-09-2013, 12:07 PM   #4
info@trinityautosport
Drives: F13 M6
usually with springs, it is recommended to let the springs settle for a couple days to a week before getting an alignment.
OP regarding negative camber, it wont hurt you too much in our opinion. the main concern would be toe, but even on our cars as long as toe is straight we run about -2 camber all around, up to -4 for the track in the front.
      05-09-2013, 04:25 PM   #5
stealth.pilot
Knight Commander
stealth.pilot's Avatar
United Kingdom
559
Drives: 2014 911 Turbo S
This is why i didn't bother with the springs. The car handles great, so this is a largely cosmetic upgrade. I'd rather have the suspension assembled by German BMW engineers, than Rusty Smith in bumblefuck, America.
Anyway hope it gets fixed soon.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      05-09-2013, 09:27 PM   #6
SSR
SSR's Avatar
Drives: F10 m5
I will get mine tomorrow and I will use the car for 200 miles and then alignment.
      05-09-2013, 10:30 PM   #7
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
Drives: 16 M5, 18 ZL1 1LE, 18 M3
you sound like me.
      05-09-2013, 10:39 PM   #8
stealth.pilot
Knight Commander
United Kingdom
559
Originally Posted by URBAN LEGEND View Post
you sound like me.
I agree with you on this one.
      05-21-2013, 09:56 AM   #9
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
All fine on this end for 2 or 3 months. Prior to my install Motorwerks asked me if I wanted any specific alignment specs and I just told them stock is fine.
Matt
      05-22-2013, 10:22 PM   #10
SSR
SSR's Avatar
Drives: F10 m5
Any one knows the OEM alignment spec ?
I have H&R springs and I want to check alignment..
      05-23-2013, 12:44 AM   #11
h4nh
h4nh's Avatar
Drives: 09 SC E90 M3 / 13 F10 M5
2009 E90 M3 (superc ...  [10.00]
2013 M5  [0.00]
I drove mine for a week then took it to BMW for alignment and everything turned out fine.
      05-24-2013, 06:33 AM   #12
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
Good to know as I will go to them when I'm ready for the install.
      05-24-2013, 11:09 AM   #13
ptt
Drives: M5
Anyone know specs? Alignment shops will say everything is "fine". I'm told there is no front camber adjustments.
m5post
