ZPOST
  TireRack
      09-26-2007, 10:26 AM   #1
jmontello
JaBaby!
jmontello's Avatar
Drives: 2004 z4 2.5i
///M Coupe rotors on a 2004 2.5i
Hey guys, does anyone know if i would be able to buy the rotors from a new ///M coupe and put them on my 2004 2.5i// i upgraded to the M6 rims and my discs jsut look so small.. any advice??
      10-07-2007, 10:46 PM   #2
BlackSapphireZ
Drives: 22 GLE 53 Coupe
you need M caliper as well as carrier...more than likely because thats what its needed for a 3.0 brake swap.
but i heard Z4M's are totally different so who knows what will be required
2022 GLE 53 Coupe
      10-24-2007, 12:30 PM   #3
pbdm4k
pbdm4k's Avatar
74
Drives: 2010 335d
Just get yourself a Brembo or StopTech BBK and it'll be much more simple than tryng to get M parts to fit.
      05-31-2008, 01:32 AM   #4
nemex12
Drives: e60,z4
but as far as i know brembo only makes brakes for the front of the z4, they dont do the rear ones(except for the ms which are very different, i think)
      05-31-2008, 04:06 PM   #5
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
To use the MZ4 rear brakes you will need the ENTIRE SUBFRAME. That means the subframe structure, the diff, the control arms, the king pin, and the output shaft. It's about $5,000 total in parts and labor.
Not entire sure if it's an upgrade worth the cost, when it's going to make your car rear heavy, accelerate like it's got a 4 cylinder engine with only 3 firing and not at the same time, make your car cruise at 4,000 RPM at 65 mph in 5th gear, and frankly, handle like SH*T because you don't have the equal springs and shocks up front.
zpost
