07-27-2013, 01:02 AM | #1 |
BimmerPost Supporting Vendor
3387
Rep 7,542
**BPMSport Performance Engine Software Tuning SUMMER GROUP BUY**
BPMSport Stage I and Stage II E9x M3 Performance Tuning Software: GROUP BUY: CLOSED The SUMMER Group Buy is HERE! Price: $899 for Stage I or Stage II (Including Cable, Support, and Tune to your specification. This also includes SERVOTRONIC Steering mapping as well!) Price for Engine Tune + DCT Software - $1499 Price for Engine Tune, DCT Software, and EuroMDM + Coding - $1875 We offer two tuning stages available for the E9x M3: Stage I is for lightly modified vehicles without changes to the primary catalysts. Stage II is tailored to vehicles that have changes to the primary cats - such as an Akra system, high flow cats, test pipe/catless, etc.. Updatability: You have the option to upgrade from one Stage to another in the future if your plans for the car change. You won't have to purchase it again, you can pay the difference between the two stages. Software Update to 240E: At BPMSport, we like to base our files off of the latest BMW Factory Software. This way any improvements that have been made to the operating code by BMW Engineers are incorporated into your tuned software. Before flashing you with our performance software, we will update you to the latest software version available from BMW. You can elect to stay on your current software level, although we do recommend taking advantage of this update. Both Stages of our Performance Tuning Software Include: -Selective mapping of the throttle response in Sport mode -Selective mapping of the throttle response in Normal mode -Raised RPM Limiter (Nmax) to 8,500 or 8,600 RPM -Removal of the Top Speed Limiter (Vmax) -Vanos changes for increased smoothness, better drive-ability, and power -Fueling and ignition timing changes suited to your modifications and octane -Optimization of ECU Torque Management and Control Parameters -Elimination of the Cold Start Routine (Makes the car smoother on cold starts) -Cold start rev limit reduction (to keep your engine happy and prevent revving too high when cold). -Launch Control Assist for 6MT vehicles (definable at 3,000 - 5,000 RPM) -NEW Servotronic Steering Tightness Changes in Normal and M-Mode You may pick whichever features suit you and we will incorporate them into the software written for your vehicle. You will experience smoother driveability, much better overall engine response, and performance increases in horsepower and torque, aside from the long list of other goodies. All software does not tamper with emissions settings. Stage II Tunes and files with cold start disabled are for OFFROAD use only. Please contact us directly with any questions regarding emissions requirements. The price of the tune includes the specially designed tuning cable. The software and cable are extremely easy to use, and we're happy to provide remote support over the computer or phone. Customer service and excellent products are our number one priority. With the software, you will be able to: -Easily flash the vehicle back to stock (this is not necessary when going to the dealer) -Easily flash in tuned files from BPMSport + potential future updates -Check your current installed software version -Read and clear engine fault codes / service engine soon lights -Check if the dealership reflashed your vehicle with stock software Horsepower and torque gains are dependent on modifications, environmental conditions, and fuel quality. Our tune will safely extract what is left on the table. Unlike other companies that focus on full throttle only, our software has been carefully crafted to create an undeniably pleasurable driving experience in part throttle (which is where you spend most of your driving!). Having owned an M3 myself since 2008, quite a lot of research in development has gone into making this software exceptionally perfect for you What happens if the dealer reflashes my car? You're in luck! The cable will allow you to flash the tune back in. If the dealer updates you to a software level past 240E, we will be happy to retune the file on the latest version FREE of charge. We like our clients ahead of the curve. The tune is 100% transparent to the dealership computers, and they will not be able to tell that the vehicle is tuned. It allows for seamless integration with their factory systems for service and diagnostics as well. (Please note that BMW will be able to see raised RPM or Speed Limits, however, the dealer can not). This calibration is a result of countless hours of street, dyno, and track testing. It is by far the best performance tune on the market, with safety, reliability, and ease of use being our primary concern. We have many clients that regularly track their cars with glowing reports. We do not turn any factory safeguards off in our tuning, and we do not desensitize the knock sensors. This means that your vehicle will run within the factory parameters and safeguards that BMW and Siemens designed for the MSS60 Digital Motor Electronics Unit. For those also interested in pairing your software tune with DCT software, the DCT software flash has the following benefits: The DCT software does the following: -Updates you to the latest DCT changes from BMW -Smoother shifting in normal driving modes -Sport mode drivelogic memory is retained -Vehicle starts in Drive instead of S -Launch control parameters are optimized and RPM is set to 3,500RPM -More aggressive shifting in higher drivelogic modes -Remapped shift patterns depending on drivelogic mode (may hold a gear longer) -Less clunky and unsmooth downshifts when stopping -Faster more precise and smoother downshift -Less lag when engaging reverse In a nutshell it improves the DCT operation all around. Normal DCT Pricing is $899. As a package deal, we are offering both of these including servotronic changes for $1499 For those also interested in our coding services, please see our coding pdf here: http://www.bpmsport.com/BPMCoding.pdf We are going to offer $125 off of coding to those that purchase engine tuning or DCT software from us. This means that the full package for your vehicle - engine software, transmission software, servotronic changes, euro MDM, and all other coding is $1899. This is discounted from the standard price of $2399 and includes both the tuning (engine/dct) cable and the coding cable as well. We also provide remote support to all of our customers for loading the software and setup. Please let us know if you have any questions and feel free to add yourself to the list. Once added, please fill out the following form and email it to order@bpmsport.com http://www.bpmsport.com/bpmorder.pdf There will be twenty slots allotted for this group buy. Please see our customers cars thread here: http://www.m3post.com/forums/showthread.php?t=854547 Thank you!
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- Last edited by BPMSport; 07-30-2013 at 12:05 AM.. |
07-27-2013, 01:06 AM | #2 |
3387
Rep 7,542
GROUP BUY: CLOSED
Paypal requests will be sent out within the next 16 hours. Please let us know if you have any questions and we look forward to BPM'ing your car.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- Last edited by BPMSport; 07-30-2013 at 12:04 AM.. |
07-27-2013, 01:07 AM | #3 |
3387
Rep 7,542
FINAL GROUP BUY LIST
Paid and Shipped!: 1. sterile stork - Stage I + Coding 2. tommy94gt - Stage II 3. M3/4 life - Stage I + DCT 4. VictorH - Stage I + DCT 5. FogCitym3 - Stage I 6. mhjeep - Stage I Only 7. IKM3 - Stage I + Coding 8. SSJVegita - Stage I + DCT 9. ibmike - Everything 10. superflywheel - Stage I + DCT 11. 206_m3 - Stage II 12. NHman - Stage I 13. signes - Stage II + Coding 14. steven26 - Stage II 15. KmndntKlink - Stage I 16. Dirka - Stage I Only 17. Top Shelf - Stage II + DCT 18. electric phua - Stage II + DCT 19. AyooooJay - Stage II 20. nightrun21 - Stage II - Awaiting Payment 21. ruff1017 - Stage I Only - Shipping on 8/2 22. HPF_E92 - Stage I - Shipping on 8/2 ALL ORDERS ARE SHIPPED!
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- Last edited by BPMSport; 08-02-2013 at 05:01 PM.. |
07-27-2013, 11:30 AM | #5 |
7494
Rep 12,310
You selling me that tuning cable was one of the best things to ever happen to my car
Get back in the game Jay!
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
07-27-2013, 11:51 AM | #6 |
M Power
81
Rep 1,293
07-27-2013, 12:35 PM | #7 |
127
Rep 357
pm sent
07-27-2013, 01:12 PM | #8 |
coupe la goon
373
Rep 1,640
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
Yay! Sending the form!
07-27-2013, 07:12 PM | #10 |
163
Rep 318
Added, thank you.
10 Slots left as of now. Please let us know if you would like to be added or post here and we will add you. For those of you on the list, please do not forget to send the order form to order@bpmsport.com Order Form Link: http://www.bpmsport.com/bpmorder.pdf *Note, we have not added the servotronic option to the order form yet, but to clarify it is included for all participants of this group buy. |
07-27-2013, 09:15 PM | #11 |
24
Rep 368
Drives: E92 M3
pm sent
07-28-2013, 04:59 AM | #14 |
24
Rep 368
Drives: E92 M3
Form sent!
07-28-2013, 08:10 AM | #16 |
Rep 469
form sent, TY
E92 ///M3 in Dakar Yellow, M-DCT, iDrive, 220M OEM rims, Active Autowerke Green filter, Turner Motorsport test pipes, BPM stage 2 tune, Stoptech ST-40 F+R in yellow.
07-28-2013, 10:36 AM | #18 |
Rep 727
Mike, we have already been exchanging PM's but please add me to the list.
Damn, I thought by buying the M3 I would've kept it close to factory (unlike my previous 335i). This forum is both informative and a drain to my disposable income. Thanks Mike.... |
07-28-2013, 02:26 PM | #19 |
163
Rep 318
Action list:
Please resend order form: sterile stork: Please resend your order form (the top portion did not come through) dirka: Please resend your order form (the form would not open) -------------------------------------------------------------------------------- 1183: It might be best to communicate via email. The forum won't let us message you due to the low post count. Please send your completed order form to order@bpmsport.com -------------------------------------------------------------------------------- Order forms NOT received from: 206_m3 tommy94gt AyooooJay 1183 ibmike NHman Top Shelf steven26: Please fill out the following order form and email it to order@bpmsport.com Order form Link: http://www.bpmsport.com/bpmorder.pdf In your email please specify the services you'd like (Tuning, Tuning + DCT, Tuning + Coding, or Full Package) -------------------------------------------------------------------------------- Forms have been received from the following: IKM3, KmndntKlink, mhjeep, M3/4 life, FogCitym3, ruff1017 Thank you for being prompt! We have 3-4 slots left for the GB. Once all of the forms are received completed, we will send paypal requests to all of the participants and get the cables shipped out. Post #3 will be continuously updated with the status of the forms, payments, and shipments. Thanks everyone! Last edited by BPM; 07-28-2013 at 02:33 PM.. |
07-28-2013, 02:26 PM | #20 |
M Power
81
Rep 1,293
+1 I feel the pain man. How's the M treating you? Did you pass the break-in period yet?
07-28-2013, 02:34 PM | #21 | |
Rep 489
2011 e92 M3, DCT, ZCP, AW with FR
07-28-2013, 02:36 PM | #22 | |
3387
Rep 7,542
***************** GB Deadlines Deadline to submit the form is Monday 7/29 at 11:59 PM PST. Deadline to submit payment is Friday 8/2 at 11:59 PM PST. We will send the paypal requests by Tuesday 7/30. If you can not meet any of these deadlines or need special arrangements, please contact us to let us know. Because we allocate a certain number of cables to a group buy, we have to have an accurate count. We've had people sign up for group buys in the past and drop out without contacting us, and this causes time delays on our end to reassign the cables. Group buy participants that drop out will not be eligible for future group buys. Participants will be removed from the list based on the deadlines above. Please make sure to follow up with us. Thanks everyone!
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- Last edited by BPMSport; 07-28-2013 at 02:52 PM.. |
