M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      08-04-2013, 10:25 AM   #1
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Downpipe Waste Gate Rattle Sound
Anyone hear their waste gates being super loud and annoying. Like a metal can rattling around or something. Especially just barely on the throttle in a garage or next to something which bounces the sound.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread:
http://www.6post.com/forums/showthread.php?t=794659
      08-04-2013, 10:48 AM   #2
Spinny02
Spinny02's Avatar
Drives: '14 M5 CP Dinan Stage 2
Hunter,
RPi made post the other day on this. I have included it below. He found and easy workaround to help.
http://f10.m5post.com/forums/showthread.php?t=872199
      08-04-2013, 10:57 AM   #3
Hunter5179
Hunter5179's Avatar
Thanks. Yeah, I've read the thread and im not sure it's the same thing.... mine does it no matter what mode and it's not a whooshing sound it's a metallic rattling sound
My Thread:
      08-04-2013, 04:46 PM   #4
noushy
///M Fan
noushy's Avatar
1657
Drives: M8 Comp, X5M Comp, iX M60
Man is that killing you. Mine I think is not as annoying. Try the sport mode thing for a while and lets see.
Noushy
2019 BMW X5 50i Mineral White/Tartufo all options including M Sport
2022 Porsche 911 C4S Silver/Brown
2023 BMW iX M60 Black Sapphire/Amido, Titanium Bronze trim/22
2023 Audi RS6 Avant Daytona Gray/Black
2024 BMW X5M Comp Brooklyn Gray/Taruma Brown, Titanium Exhaust on order
      08-04-2013, 08:40 PM   #5
MasterDank
Boats & Hoes
MasterDank's Avatar
Drives: 13 F10 M5 Sakhir Orang,Chohiba
I have this sound and am not sure if its a fitment issue or what.
I have had many turbo cars and waste gate flutter isn't annoying to me either.
But I hate rattles and exhaust leaks.... This noise is definitely a rattle but I don't hear an exhaust leak so Im getting a little lost with wear its coming from, I have been to lazy to put it up on a rack to take a good look.
If you figure it out let me know..... Take it to IND and have them figure it out for us...
Aloha
Alex
Change is inevitable Progress Is optional
      08-04-2013, 08:47 PM   #6
Hunter5179
Hunter5179's Avatar
Where would you say the sound is coming from? What area.
My Thread:
      08-04-2013, 09:47 PM   #7
Grayblack
Grayblack's Avatar
182
Drives: E92 M3 and G07 X7
Are you guys running catted or catless?
      08-04-2013, 09:54 PM   #8
Hunter5179
Hunter5179's Avatar
Catted.... its definitely not the downpipes.
My Thread:
      08-05-2013, 01:06 AM   #9
MasterDank
Boats & Hoes
MasterDank's Avatar
Cattless for me..... Id say from the DP area, but sometimes its sounds further back.
Aloha
Alex
      08-05-2013, 07:35 AM   #10
Hunter5179
Hunter5179's Avatar
Noushy
Yeah, I tried that too.... If it's normal waste gate noise fine but I'm going to have it checked out just to be sure and report back.
My Thread:
      08-05-2013, 07:46 AM   #11
noushy
///M Fan
noushy's Avatar
1657
Mine is only an issue when cold and low throttle low speed. Once warmed up I rarely hear it. Wondering if something else is loose. Need to have them lift it and check all clamps and bolts also make sure they are properly torqued down. My tech is fanatical and he torques every bolt to factory or better depending on specs.
      08-05-2013, 08:14 AM   #12
Hunter5179
Hunter5179's Avatar
Yeah I will. It does sound just like the waste gates...but looser. I will have them check everything out this week. I remember the tech once was checking for a sound my car was making that ended up being the brakes but before we knew where it was coming from he checked the exhaust and he said he yanked on it hard in some area to check fitment and it's after that day I remember hearing it, and it has gotten worse so it must be something loose.
My Thread:
      08-05-2013, 08:41 AM   #13
Fly M5
Drives: 2014 M6GC CP & 2015 M3
I believe it's the valves on the muffler. I have the Akro and stock DP and i hear the same thing on cold start. Just haven't had time to get it readjusted.
Current: 2014 M6GC CP and 2015 M3
Past: 2013 M5, 2012 E63, 2011 panamera turbo, 2010 E63, 2010 GTR, 2009 C63, 2008 M5
      08-05-2013, 08:44 AM   #14
Hunter5179
Hunter5179's Avatar
Mine is not just during cold start. It's all the time.
My Thread:
      08-05-2013, 09:24 AM   #15
Nate@IND
Nate@IND's Avatar
2868
Drives: BMW
Sure it's not a rattle coming from a heat shield? I would have it checked out by Patrick.
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
      08-05-2013, 12:27 PM   #16
MasterDank
Boats & Hoes
MasterDank's Avatar
That was my first guess, but I checked and its all tight unless its the second mounting point touching the heat shield.... I hear it behind me sometimes... I need to check the rear section to rule it out. I might have tweaked it during DP install.
Aloha
Alex
      08-20-2013, 06:25 PM   #17
Hunter5179
Hunter5179's Avatar
Ok so I went to AMS and they poked around a little. I had a friend of mine upload the vids on YouTube so here are some links. The first link is what the guys at AMS thought was the problem initially and it sure looked like that was the case. It's a waste gate rod or something that has a lot of play and can be the cause of some noise under the hood but again that's normal and not what I'm experiencing. Here is the link to show the rod that is attached to each waste gate(one on each side)
The guys at AMS did something with the tension to see if this was the actual noise I'm hearing and it is not. Secondly the guys at AMS shut the waste gates so that they do not open to see if the rattling I'm hearing is wastegate related and the result is negative. Even with the wastegates shut the car still makes the same rattling.. I've been to the dealer and they can't find what's going on either... I have an appointment with AMS 8/21/13 and I will leave the car there a couple of days so they can locate what exactly is the reason for the rattling I'm experiencing... I will also drop the car off again at the dealer where they will look over it again and check all the clamps, bands and whatever... whatever I'm experiencing is not normal for sure and not because of the downpipes and apparently not because of the wastegates either. Below is a link to a vid of my car at idle and im just barley tapping the gas.
My Thread:
      08-20-2013, 07:39 PM   #18
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
Yep something is really loose. Hope you find it.
      08-20-2013, 08:00 PM   #19
runningthingz
runningthingz's Avatar
21
Drives: Frozen White M5
I hear the same thing on mine after I had the catted AMS downpipes installed. Pretty damn annoying.
      08-20-2013, 08:03 PM   #20
Hunter5179
Hunter5179's Avatar
Do you hear it like mine at idle? Like this vid just tapping the gas?
My Thread:
      08-20-2013, 08:44 PM   #21
boots
Curve Thrasher
boots's Avatar
623
You guys are scaring me from making that move.
      08-20-2013, 09:27 PM   #22
Hunter5179
Hunter5179's Avatar
Don't be scared boots. Not sure what is going on yet.. it will be sorted out soon. I love the downpipes.. I don't regret purchasing them... stay tuned
My Thread:
m5post
