08-28-2013, 11:02 AM | #1 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
**BPMsport Tune + Akrapovic Evolution Titanium Exhaust**
BPMsport is proud to announce a top-of-the-line pairing between our BPMsport tune and one of the best exhausts you can buy, Akrapovic!
About the tuning: We offer two tuning stages available for the E9x M3: Stage I is for lightly modified vehicles without changes to the primary catalysts. Stage II is tailored to vehicles that have changes to the primary cats - such as an Akra system, high flow cats, test pipe/catless, etc.. Updatability: You have the option to upgrade from one Stage to another in the future if your plans for the car change. You won't have to purchase it again, you can pay the difference between the two stages. Software Update to 240E: At BPMSport, we like to base our files off of the latest BMW Factory Software. This way any improvements that have been made to the operating code by BMW Engineers are incorporated into your tuned software. Before flashing you with our performance software, we will update you to the latest software version available from BMW. You can elect to stay on your current software level, although we do recommend taking advantage of this update. Both Stages of our Performance Tuning Software Include: -Selective mapping of the throttle response in Sport mode -Selective mapping of the throttle response in Normal mode -Raised RPM Limiter (Nmax) to 8,500 or 8,600 RPM -Removal of the Top Speed Limiter (Vmax) -Vanos changes for increased smoothness, better drive-ability, and power -Fueling and ignition timing changes suited to your modifications and octane -Optimization of ECU Torque Management and Control Parameters -Elimination of the Cold Start Routine (Makes the car smoother on cold starts) -Cold start rev limit reduction (to keep your engine happy and prevent revving too high when cold). -Launch Control Assist for 6MT vehicles (definable at 3,000 - 5,000 RPM) -NEW Servotronic Steering Tightness Changes in Normal and M-Mode You may pick whichever features suit you and we will incorporate them into the software written for your vehicle. You will experience smoother driveability, much better overall engine response, and performance increases in horsepower and torque, aside from the long list of other goodies. All software does not tamper with emissions settings. Stage II Tunes and files with cold start disabled are for OFFROAD use only. Please contact us directly with any questions regarding emissions requirements. The price of the tune includes the specially designed tuning cable. The software and cable are extremely easy to use, and we're happy to provide remote support over the computer or phone. Customer service and excellent products are our number one priority. With the software, you will be able to: -Easily flash the vehicle back to stock (this is not necessary when going to the dealer) -Easily flash in tuned files from BPMSport + potential future updates -Check your current installed software version -Read and clear engine fault codes / service engine soon lights -Check if the dealership reflashed your vehicle with stock software Horsepower and torque gains are dependent on modifications, environmental conditions, and fuel quality. Our tune will safely extract what is left on the table. Unlike other companies that focus on full throttle only, our software has been carefully crafted to create an undeniably pleasurable driving experience in part throttle (which is where you spend most of your driving!). Having owned an M3 myself since 2008, quite a lot of research in development has gone into making this software exceptionally perfect for you What happens if the dealer reflashes my car? You're in luck! The cable will allow you to flash the tune back in. If the dealer updates you to a software level past 240E, we will be happy to retune the file on the latest version FREE of charge. We like our clients ahead of the curve. The tune is 100% transparent to the dealership computers, and they will not be able to tell that the vehicle is tuned. It allows for seamless integration with their factory systems for service and diagnostics as well. (Please note that BMW will be able to see raised RPM or Speed Limits, however, the dealer can not). This calibration is a result of countless hours of street, dyno, and track testing. It is by far the best performance tune on the market, with safety, reliability, and ease of use being our primary concern. We have many clients that regularly track their cars with glowing reports. We do not turn any factory safeguards off in our tuning, and we do not desensitize the knock sensors. This means that your vehicle will run within the factory parameters and safeguards that BMW and Siemens designed for the MSS60 Digital Motor Electronics Unit. About the exhaust: Evolution Line (Titanium) The Evolution performance exhaust system for the BMW M3 consists of dual-outlet mufflers, flow-optimized link pipes, and an X-pipe that incorporates high-flow 100 cpsi sports catalytic convertors and resonators. The power and torque gains of the BMW M3 with the Evolution system are just amazing. A substantial increase is detected over a very wide rpm range, and so it increases responsiveness during all phases of driving. Together with incredible weight savings, the Evolution system dramatically changes the power-to-weight ratio. Our goal was to design a system that delivers a deep, rich growl at cruising speeds while also allowing the driver to enjoy an aggressive roar when driving hard. Complete the look with a set of two exquisite tailpipes in titanium or carbon fibre. Here you can see a factory video of the exhaust in action: Because of this offer, we are currently limiting this to the first 10 customers. The total for the engine tune + Akrapovic Evolution exhaust (with standard titanium tips) is $6700 shipped in the CONUS!! 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. |
08-28-2013, 11:02 AM | #2 |
307
Rep 13,093
Reserved.
10-04-2013, 04:32 AM | #3 |
Rep 183
Although I won't be buying just yet (gotta save up first), I'm wondering if there is a possibility to ship to Canada? Or is it US only?
Now have 2016 M4
2013 E92 M3 /// Mineral White /// Black Novillo Leather /// Competition Package /// Fully Loaded /// CF Roof, Mirrors, Spoiler, Front Diffusers /// Hellst XRT LED Angel Eyes /// BPMSport Tune Stage 1 |
10-04-2013, 09:19 AM | #4 |
307
Rep 13,093
10-04-2013, 04:04 PM | #6 |
307
Rep 13,093
10-15-2013, 11:35 AM | #7 |
307
Rep 13,093
Plenty of exhausts available!
10-16-2013, 06:59 PM | #9 |
Rep 51
Hello there
I am looking to buy the akrapovic slip on to try it first before I move with the Evo . Can you let me know if you are running any special and how much it will cost me shipped to 22204 please. Thanks!!! |
10-25-2013, 07:27 AM | #10 |
///M Flight
Rep 21
Drives: 2011 E90 JB M3
How much with the DCT tune also included in the package
10-25-2013, 10:45 AM | #11 |
307
Rep 13,093
10-25-2013, 10:46 AM | #12 | |
307
Rep 13,093
11-08-2013, 01:34 PM | #13 |
307
Rep 13,093
Only a couple left!!
11-14-2013, 09:54 AM | #14 |
307
Rep 13,093
We are now offering support for Mac/Apple computers using our specifically designed Virtual Machine!!
11-25-2013, 04:20 PM | #16 |
307
Rep 13,093
11-26-2013, 12:26 PM | #17 |
Rep 2,991
Drives: 13E92 MCB M3 18 F80M3 Atlantis
Have akra system pm me on price of stage 2 tune. thank you
| 2013 M3 Coupe | Individual Monte Carlo Blue || ESS VT2-625 Kit| KW Clubsports | OSS Headlights | HRE590RS | Brembo | BMW Performance Seats
| Dinan Strut Tower | Dinan Midpipe | Akra Slip-on | Valentine 1 Built-in Radar Detector |
11-26-2013, 12:27 PM | #18 |
307
Rep 13,093
