GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      09-26-2013, 11:20 AM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
BMW M3 M4 RPM Redline Visual, Finally
BIMMERPOST NEWS
295
COMMENTS
We've now had confirmation of the s55 engine's sightly above 7500 RPM redline via the official released specs, but seeing as how the tachometer and redline were ever elusive all these months and years of spy photos, we're happy to finally share with you images of the M3/M4's redline.
Though the actual redline starts at the 7500 mark, expect the rev limiter to kick in a bit after that.
Dyno Plot For Reference.
      09-26-2013, 11:43 AM   #2
solstice
Drives: 2015 M3 6MT
Thanks!
With that picture combined with the Dyno chart I think it's safe to say that this engine will act like a typical FI engine in terms of power delivery across the rev band.
With a 7500 rpm redline it looks from the dyno chart that plots the S65 on it as well that the power plateau should be around 5500 rpm. I.e when power stops building and maintain hp until redline. The quick run to peak hp and the square tq curve will make for a very fat midrange but the car will not be very exciting to rev past 5500 - 6000 rpm. The ferocious pull to redline from the S65 will not be there.
I.e much more S63TU than S65 as expected. No surprise here.
Remains to see if throttle response ( I inlcude all type of lag from throttle to engine response in "throttle lag" ) will set this engine apart from a typical FI engine.
      09-26-2013, 11:45 AM   #3
Holset
Sweden
274
Drives: F90 M5 Comp LCI
Okay so about 7500 rpm were is the rew limit 7700-7800rpm?
      09-26-2013, 11:48 AM   #4
solstice
Drives: 2015 M3 6MT
Does it matter when taken the dyno curves shifting before redline will give a more satisfying experience and better performance than running above redline?
      09-26-2013, 11:49 AM   #5
Boss330
Boss330's Avatar
1718
Drives: BMW
Nice find, suspect that official redline is 7600rpm (slightly above 7500rpm has been claimed by BMW).
In the onboard videos it seems like the drivers shift well before 7500, in fact under 7000rpm. Which makes sense as acceleration will be greater in the next gear instead of pushing to the redline like you would in a NA engine.
I guess that the short stroke will improve response compared to the N55 at least
      09-26-2013, 11:52 AM   #6
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
Originally Posted by solstice View Post
Thanks!
With a 7500 rpm redline it looks from the dyno chart that plots the S65 on it as well that the power plateau should be around 5500 rpm. I.e when power stops building and maintain hp until redline. The quick run to peak hp and the square tq curve will make for a very fat midrange but the car will not be very exciting to rev past 5500 or 6000 rpm, max. The ferocious pull to redline from the S65 will not be there.
My thoughts exactly. This engine is going to deliver and feel exactly like +500 rpm and +20% more peak power 1M (N54T).
Our redline is at 7000, power plateau is around 5000 and in terms of excitement there is not much past 5500 or 6000, despite the fact that it can hit the rev limiter pretty easily. It just is not that exciting to do so, in comparison to gobs of power available at low and mid range revs which is stupid fun!
It really sounds to me like a very well tuned 1M engine with an extra 500 rpm on tap. I am not talking about other new stuff and enhancements like in the cooling.
I bet the throttle response will in practice mimic the M button in the 1M as well (controlling wastegate, a different map) for sharp response , which I posted before as being NOT as natural as a good NA engine, like the S65 because it may be oversensitive and jerky at times. But maybe they fixed that too. S55 might just be the best FI engine in terms of response, as you defined it, since 1M was already very good compared to others, including other applications of the N54.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      09-26-2013, 12:13 PM   #7
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
Not bad for a factory turbo car.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      09-26-2013, 12:13 PM   #8
Powaup
Powaup's Avatar
Drives: 2021 Supra 3.0 (Past: 2015 M23
2015 BMW M4  [10.00]
Looks spot on 7500 but I'm sure the rev limiter won't come in until 7800ish
Check out my YouTube Channel Powaup
Instagram: @ Powaup
      09-26-2013, 12:17 PM   #9
swamp2
swamp2's Avatar
Drives: E92 M3
, which I posted before as being not as natural as a good NA engine, like the S65 because it may be oversensitive and jerky at times. But maybe they fixed that too. S55 might just be the best FI engine in terms of response, as you defined it, since 1M was already very good compared to others, including other applications of the N54.
I completely agree esp. the bold part. However, I think you feel this is more or less a win, whereas it's pretty disappointing for me. Only time and drives by journalists will really tell us about the throttle response.
In my most recent simulations the (approximate) shift points were less than redline in all gears except 1-2. In particular they were (that sim still is using a 7750 redline):
1-2: 7750 (redline)
2-3: 7100
3-4: 6600
4-5: 6500
5-6: 6300
6-7: 6200
This is simply the nature of the beast with a radically falling torque curve and flat power curve. The force at the wheels curves by gear vs. vehicle speed simply overlap and that is the ideal shift point for maximum performance. I guess we've pretty much known this since the revelation that the car would be turbo charged but it's really sinking in now. In short, other than in 1st gear, forget about the redline and forget about the corresponding thrills of a high redline. Redline will only be utilized for absolute drag racing starting in 1st gear.
Here is an interesting related question. Will the shift points for the DCT be programmed for maximum performance which means essentially short shifting? Ugh...
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      09-26-2013, 12:17 PM   #10
Danyutz
Danyutz's Avatar
Romania
89
Drives: Mini Cooper
That doesn't look black panel tech to me, still looks analog, except for the yellow/red line.
      09-26-2013, 12:19 PM   #11
Suave
Suave's Avatar
Drives: GT4 and M2 in progress
is this view of the dash claimed to be production version? I do like it...
201X ???? Coming soon
2015 F80 M3 AW/SO - Going Going Gone!
      09-26-2013, 12:20 PM   #12
ASAP
ASAP's Avatar
10161
Drives: '23 X3 M40i
mkoesel? tie? still not a definitive answer
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
      09-26-2013, 12:21 PM   #13
Ashley Schaeffer BMW
91
Drives: E92 M3
lol whats with some of you always bumping up the numbers??
This site has been spot on thus far in predictions and news yet the same people with no insider sources saying 425?? Hmmm more likely 450HP.... 390lb torque?? Hmmm more likely 410lb.... 7500 redline? Hmmm more likely 7800.
      09-26-2013, 12:23 PM   #14
r3dbimmer89
r3dbimmer89's Avatar
331
Drives: P-Car
My thoughts exactly, a 7600 redline... not much more you can do with an FI engine. Overall, I am still really impressed. I am hoping that power doesn't fall off after 6k RPM like the N54/N55 but if so then oh well...
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus
Present: 24 992 C2
      09-26-2013, 12:23 PM   #15
325rider
Drives: '11 e90 M3 6mt
Anyone think the e46/e9x gauges were way sweeter and more proprietary looking? Cool new M, the passions in the transmission and the motor tho, and I prefer a std. 6 mt and NA motor.
Great car tho
I definitely think its going to have a 7550 rpm redline though, no way 7500, NO WAY
      09-26-2013, 12:24 PM   #16
GOLFFRR
GOLFFRR's Avatar
10817
Drives: GOLFFRR cart
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      09-26-2013, 12:29 PM   #17
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
1-2: 7750 (redline)
2-3: 7100
3-4: 6600
4-5: 6500
5-6: 6300
6-7: 6200
That is a good question, don't remember much info regarding the DCT in the new car too, practically same as the one in E9X?
By the way, I don't really consider it as mind blowing news but yes I guess, having driven a nice little M car since two years it is less of an issue for me to worry about the response and revs.
I don't remember any occasion the car doesn't surprise and excite me, it always puts a smile on my face and this feeling doesn't get old so I have some faith in M engineers that they should have done it even better in the M4/M3, why and how they couldn't?
Just it is a big car, that's what really bothers me, nothing about the engine.
      09-26-2013, 12:31 PM   #18
Suave
Suave's Avatar
1-2: 7750 (redline)
2-3: 7100
3-4: 6600
4-5: 6500
5-6: 6300
6-7: 6200
Great input Ozinaldo and Swamp!
      09-26-2013, 12:32 PM   #19
NISFAN
NISFAN's Avatar
United Kingdom
3489
Drives: BMW M2
And thank goodness for that, the black panel instrument cluster in the 7er is vile.
Is HUD standard in M3/4 like M5/6?
      09-26-2013, 12:35 PM   #20
SoCalS2k
SoCalS2k's Avatar
450
Drives: S2K!
2001 Honda S2k  [8.50]
3 and 4 series have HUD so I'm sure we'll see it as standard on M3 and M4, and with M mode like on M5/M6.
      09-26-2013, 12:35 PM   #21
Holset
Sweden
274
Just curious.
      09-26-2013, 12:37 PM   #22
jhv
jhv's Avatar
1699
Drives: G80 M3
gotta love that dyno!
Tags
2014 bmw m3, 2014 bmw m3 horsepower, 2014 bmw m3 specs, 2014 bmw m4 horsepower, 2014 bmw m4 specs, 2014 m3, 2014 m3 engine, 2014 m3 forum, 2014 m3 horsepower, 2014 m3 hp, 2014 m3 specs, 2014 m3 weight, 2014 m4 engine, 2014 m4 horsepower, 2014 m4 hp, 2014 m4 specs, 2014 m4 weight, 2015 bmw m3, 2015 bmw m4, 2015 m3, 2015 m3 engine, 2015 m3 specs, 2015 m4, 2015 m4 engine, 2015 m4 hp, 2015 m4 weight, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 s55, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3 coupe, bmw f82 m4, bmw f82 m4 coupe, bmw f82 m4 s55, bmw f82 m4 video, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m3 carbon fiber roof, bmw m3 forum, bmw m3 forums, bmw m3 s55, bmw m3 s55 engine, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 curb weight, bmw m4 forum, bmw m4 redline, bmw m4 rev limit, bmw m4 rev limiter, bmw m4 rpm, bmw m4 rpm redline, f80 m3 redline, f80 m3 rev limit, f80 m3 rev limiter, f80 m3 rpm, f80 m3 rpm redline
f80post
