Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > Commercial Classifieds [6 Series and M6]
      10-30-2013, 10:14 AM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
814
Drives: Independent Tuning Specialists
:: ECS Tuning :: Schwaben Tools|Brake Caliper Essentials
Rule #1: Use the right tool for the job. These brake caliper tools from Schwaben are essential for changing your pads or bleeding your brake fluid in your German automobile.
If your caliper pistons need to be simply pressed back in, or if they're threaded and require screwing back in, we've got the caliper piston tool you want.
Bleeding your brakes? Our Schwaben brake bleeder wrench makes it so easy, you can even do it without having to remove your wheels!
Make sure you're prepared with the right tool for the job with these Brake Caliper Essentials from Schwaben Tools.
Click HERE for your Schwaben Caliper Piston Compressor Tool
Click HERE for your Schwaben Brake Caliper Piston Tool Kit - 11 Pieces
Click HERE for your Schwaben Brake Caliper Piston Tool Kit - 18 Pieces
Click HERE for your Schwaben Brake Bleeder Wrench
Tags
brake, easy, tool, winning
6post.com
