ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Cosmetics Modification (Exterior/Interior) Discussions
  TireRack
      11-16-2007, 07:24 PM   #1
jefflazo
Drives: Mini Countryman
mtec HID installation
If any of you have done the mtec HID installation, where did you mount the ballast? Inside the light housing? Or did you mount it outside and drill and use a grommet to fill the hole?
Just switched to Sylvania bulbs to see if I can hold back on the HID kit...
      11-16-2007, 09:49 PM   #2
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
You should be able to fit it inside the headlight cover, it'll probably be a better bet to fit it in there then drill a hole and use a rubber gasket.
      11-16-2007, 10:38 PM   #3
jefflazo
If it is inside the weathersealed enclosure, is there a need to drill? All of the wiring should be enclosed, no?
      11-16-2007, 10:55 PM   #4
BimmerZealot
There shouldn't be, you should be able to plug the stock H7 connector probably into a adapter cable H7-->9006 then into the ballast, ballast goes to the bulb and you should be able to tuck everything inside, close the cover and snap on the metal bar thing.
      11-16-2007, 11:56 PM   #5
jefflazo
Thanks guys. It looks like there are a couple of kits that allow for a direct connect to the ballast without a 9006 adapter. Now I just have to be confident that they will not throw a bulb error.
      11-17-2007, 12:20 AM   #6
jefflazo
Do you still work for the company that you referenced in other HID posts?
      11-17-2007, 03:51 PM   #7
BimmerZealot
Not at the moment I may be in a few weeks.
      11-20-2007, 01:21 AM   #8
chaforjohn
Drives: 2006 Black M Coupe
I'd drill the rear cover and use a grommet to seal it in.
      11-21-2007, 02:41 PM   #9
Chuck I
Chuck I's Avatar
Drives: '03 Z4 + '07 ///M Roadster
I removed my front bumper today..
I'm in the process of installing a new Aero front bumper and while it's off I thought I would show you how I put in my MTEC hids... I actually used heavy duty velcro to attach the unit to the side in front of the wheel well. They have been there for over a year and have not moved... Not much water gets in that area, but I mounted them up little bit just it case. The kit came with a gromet to go around the headlight wire.. I did have to drill a hole in the cover... but it can be easily plugged if I remove the hids...
      11-24-2007, 08:00 PM   #10
jefflazo
Chuck,
Thank you so much for the images! Just out of curiosity, do you get any dash errors on the low beams with the kit installed?
      11-26-2007, 06:13 AM   #11
BMW^Z4
BMW^Z4's Avatar
Drives:
can I install mtec without removing front bumper ?
Sterling grey ,108 starspoke, alarm,KW v3 suspension,clear lights,cd/mp3, ipod 20GB, hardtop,manual,wind deflector, aerodynamic package, silver trim,Michelin pilot sport tyres, cruise control etc ...http://www.freewebs.com/knb921/
      11-26-2007, 06:34 AM   #12
Chuck I
Chuck I's Avatar
No errors... more
I get no errors at all... I installed mine by pulling back the rubber wheel well... it's very flexible. You just have to remove the 4 plastic pins in the expanding rivets connecting the wheelwell to the front bumper and a couple screws over the wheel. You have to remove the wheel.. The whole job took about 30 minutes... Hope this helps..
      11-26-2007, 10:44 AM   #13
BMW^Z4
BMW^Z4's Avatar
Drives:
where did you install ballast?
      11-26-2007, 11:15 AM   #14
BMW^Z4
BMW^Z4's Avatar
Drives:
from where did you get power for the ballast ?
      11-26-2007, 12:18 PM   #15
BimmerZealot
You dont even need to remove your fender lining, removing the upper panel in your wheel well should be plenty of access. The ballast is powered by your stock halogen bulb wiring and you can mount the ballast anywhere that is stable and dry. Most people either double sided tape or zip tie it to a support brace.
      11-26-2007, 12:25 PM   #16
Chuck I
Chuck I's Avatar
That is te ballast
That is the ballast mounted in my pictures above. It is very easy.. you simply remove the cover to the back of your light, then pull the headlight wire back. Plug that wire to the ballast. Mount the ballast. New Hid bulbs come with the kit. You have to drill a hole in the cover and run the new bulb wire through it (there is a gromet that seals the hole). Plug that wire into the ballast and your done... no errors.. Just make sure you get the real MTEC hids... it looks like there are some fakes out there. Also, as I remember now, I did the install through the access port in front of the wheel... I had to fold back the wheelwell when I put in the fog lights... Chuck
      11-26-2007, 02:26 PM   #17
Santa Fe Roadster
Member
Santa Fe Roadster's Avatar
Drives: 2003 Z4 2.5 Sport
Great advice & pics! Just purchased the mtec kit and was unsure about the install. Now I think I'm ready!
BMW rear spoiler - de-badged - MTEC HIDs (DEFECTIVE) - XENESIS high beams & fogs - shadowline front grill - 20% tint - keyhole plugs - Roadster Solutions acrylic wind deflector - LeatherZ center console & door arm rests - Parrot 3100 bluetooth - USA SPEC IPod integration - Xenon interior lighting
      11-27-2007, 10:09 AM   #18
jefflazo
Chuck, thank you so much for the tips!
      11-27-2007, 12:10 PM   #19
BMW^Z4
BMW^Z4's Avatar
Drives:
from where did you get power?
      11-27-2007, 12:15 PM   #20
Chuck I
Chuck I's Avatar
Power
It gets it's power from the original light sourse (the wire that now connects to your bulb).. no other power is needed... Chuck
      11-27-2007, 01:44 PM   #21
narcolo
narcolo's Avatar
Drives: E85 E89 Z4
just wondering, where did everyone purchase their MTEC HID kits from? Is Ebay the only option? and if so who is a reputable seller?
      11-27-2007, 01:58 PM   #22
Santa Fe Roadster
Member
purchased on EBay from "mtecpower". The delivery charges were minimal and the devlvery time was fast.
zpost
