03-28-2014, 12:34 AM | #1 |
Rep 150
Redline ATF 4/6 6MT
I have noticed that around the other side of the world, they use Redline ATF 4 or 6 in the 6 speed manual. Its even the recommended product on the US Redline site. However, in Australia the recommended product is a manual gear oil.
Has anyone tried this in their 6 speed? Is the difference perhaps the fact that we live in a significantly warmer climate? |
03-28-2014, 01:25 AM | #3 |
Rep 2,682
I use redline MT-60 in mine. Works pretty well. Don't really have much to compare with. I guess it feels a little smoother than the OEM fluid I had in there before. Haven't tried the ATF though.
03-28-2014, 01:36 AM | #4 |
Rep 183
I use redline MTL in mine. I have seen people that rebuild BMW gearbox only uses MTL. With the exception of people who won't warm up their box before 'spirited' shifting, then use ATF D4. In other word, MTL give the best protection given that you don't hard shift when cold.
2008 BMW M3 | 6MT | OEM Exhaust Mod | Black Grilles | |
03-28-2014, 01:48 AM | #5 | |
Rep 2,682
03-28-2014, 01:49 AM | #6 |
Rep 2,682
Here, have a read of this.
http://www.redlineoil.com/content/fi...ech%20Info.pdf They say that ATF isn't suitable for manual transmissions because "are not well suited for transmission use because of two factors - shear stability and improper coefficient of friction". Whatever that means. The article does state later on however that D4 ATF can be substituted for MTL as they're both GL-4 lubricants. Whatever that means.
03-28-2014, 02:12 AM | #7 |
Rep 133
Poking around abit it appears the D6 is closer in spec to the BMW LT-3 MTF, but both D4 and D6 meet GL-4, so what this means in the real world I have no idea.
So in conclusion.. I'm still confused! Hopefully I don't grenade my gearbox |
03-28-2014, 03:14 AM | #8 | |
Rep 2,682
But in the end, no ATF should be completely fine and you won't lunch your gearbox. You can also shift harder without having to warm up the fluid as much compared to MTL. It just may not be as smooth as if you were to use MTL once warmed up.
03-28-2014, 03:50 AM | #9 | |
Rep 133
Hmm, well I guess if I dont like the shift feel I can always change it to MTL later. See how I go next week! |
03-28-2014, 04:27 AM | #10 |
European Editor
10589
Rep 22,992
This is interesting. I have been using D4 in my manual trans for about 35K miles now. No problems what so ever. I also have used it in a former BMW (e36) for 70K miles, with no problems. I think its the differences climates.
In the US most people(and Redline) say to use ATF D4(or D6), some bmw guru's say to use MTL or MT90, with the caveat that you can not shift fast on a cold trans. I think Mike Miller is one of those guys. He also says that IF he can not trust his customer to wait until the trans warms up.. he uses D4. Personally I think you'd be fine using any of these fluids.
03-28-2014, 05:27 AM | #11 |
Rep 150
I guess the thing is that I do a lot of smaller trips. As a result the oil doesn't get a chance to get warm. I definitely notice a difference in the shifting when the gearbox is warm. I like notch (warm) but not clunky (cold) if that makes sense? It may just be that it needs something better than what is likely the oil that it came out of the factory with 65000km ago. I also figure that surely some states have similarly warm temperatures to QLD and their US website recommends it over the gear oil.
03-28-2014, 06:30 AM | #12 |
Rep 2,682
I think any of the compatible fluids/oils will be better than whatever's been festering in your gearbox for god knows how long.
03-28-2014, 07:01 AM | #14 |
Rep 809
Been using D4 for 6 months or so, initially noticed bugger all difference then it started to free up over a few weeks.
It was definately worthwhile for the sake of $50-60 worth of fluid. |
03-28-2014, 07:05 AM | #15 |
Rep 6,196
I chose D4 as per Redline's recommendation for my tranny. I live in Canada however, so I need to be able to shift at -30 C. Something the D4 does MUCH better than the stock MTF-LT-5. Nice that the D4 is also the recommended fluid for the power steering.
03-28-2014, 06:57 PM | #16 |
Rep 809
Damn that's crazy cold! You might be better of with the D6 fluid?
03-28-2014, 07:11 PM | #17 |
European Editor
10589
Rep 22,992
You have to look at the PS cap on BMW's to make sure that you can use ATF. Some cars have a cap that says "use CHF 11S" fluid. So it's on a car by car basis.
03-29-2014, 10:04 AM | #18 | |
Rep 6,196
Any synthetic is going to be better than the dead dino juice that comes pre-loaded in our boxes. I also plan on doing a fair amount of lapping with the car this summer, so I wanted something that can do dual duty. |
03-29-2014, 10:05 AM | #19 |
Rep 6,196
I think it says ATF on my cap, but will double check. On the Redline site, D4 is the recommended fluid for my car.
03-29-2014, 10:14 AM | #20 |
Rep 454
I went with Redline MTL at my 1,200 break-in service. It's noticeably smoother than OEM and I haven't had any issues whatsoever.
2013 Jet Black 135is | 6MT | Coupe | #381/586
03-29-2014, 05:26 PM | #21 | |
Rep 809
Wouldnt the fluid bmw use have to be a full synthetic also to be a 'lifetime fluid'? All I know is the oem stuff reeks when you drop it! |
03-30-2014, 07:40 AM | #22 |
Rep 3,099
I've used the D4-ATF and have no problems with it
another one i've seen come up on forums for N54's is Red Line MT-90, apparently it's even better. |
