04-01-2014, 07:26 PM | #1 |
19
Rep 313
I'm contemplating investing in coilovers for my 1M, so wondering who locally is running an Ohlins setup and details (which springs?). Also, did u source locally or from o/s?
Thanks in advance... |
04-01-2014, 07:34 PM | #2 | |
Breakfast at Tiffany's
24
Rep 1,053
The guys at Advan have seen plenty of them on race and track cars over the years. |
04-01-2014, 08:16 PM | #4 |
Rep 2,682
PeteA as well as Nugget are running them from memory. I think Nugget ordered them from an Australian dealer and Pete from HPA.
04-01-2014, 08:57 PM | #5 | |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
The 1M is a different kit though(same as M3), and most people seem to run the springs that come with the kit. |
04-01-2014, 09:17 PM | #6 |
Rep 1,054
Mines a hybrid set. 135i front 1M rear (did camber link conversion).
Swift sprints also (7" 60Nm / 9" 120Nm) if I recall. Check build thread for details. If you have any targeted questions let myself or nugget know. Going a 7" front sprint helped bigtime on wheel clearance btw so I recommend that. |
04-02-2014, 04:53 PM | #7 |
19
Rep 313
Thanks guys, appreciate prompt response. Just started looking in to this...
I've seen Harold's blurb on Swift springs, just curious to see how that translates for you in DD or track work. Any comparison to stock springs? |
04-02-2014, 06:14 PM | #8 |
Rep 2,682
I have swift springs matched to my moton Clubsport shocks. 135i fronts and 1M/M3 rear with solid subframe bushes. 560lb/10kg fronts and 800lb/14kg rears. Even though they're 2-3x the stock spring stiffness with the shocks set to full soft it's pretty good for daily driving.
Happy to take you for a ride sometime.
04-02-2014, 08:00 PM | #10 | |
Rep 2,601
I initially used the front spring that came with the kit and a rear swift spring. Then switched to a shorter stiffer front spring because of tyre clearance issues. I think the ride actually got better when I did that, maybe because front/rear balance was better, I'm no expert though. Car is definitely firm but still rides nicely IMO. It's definitel stiff enough for my tyres on the track as well (I'm not using R-Comps yet). Here is a comparison of the springs that come with the Non-M E90/E82 kit and the swift springs I ended up with. |
04-10-2014, 12:07 AM | #11 | |
19
Rep 313
04-10-2014, 12:08 AM | #12 |
19
Rep 313
04-10-2014, 03:41 AM | #13 | |
Rep 1,147
set at hard for the track with semi slick 18's its a very quick set up. on 19's at about 35% its very smooth on country roads. but don't change the oem heights, this is important how much are ohlins? |
04-23-2014, 04:14 PM | #14 |
19
Rep 313
Guys, thanks for your help. I was at a decision point to either sell the car or spend some serious dough on it...suspension etc. I've gone with the former.
I'll loiter around and hope to see some u folks at meets etc. |
04-28-2014, 10:11 AM | #15 | |
Rep 444
04-28-2014, 10:13 AM | #16 | |
123
Rep 1,852
04-29-2014, 06:19 PM | #17 |
19
Rep 313
I couldn't come to terms with the new M4 pricing. With a handful of decent options (LED, full Leather, no CCB or Sunroof) the price came out at over $190....insane! I cancelled my build slot, which is in 3wks.
04-29-2014, 06:22 PM | #18 | ||
19
Rep 313
I set out to buy a CaymanS, but In the end couldn't justify $40k extra when 2.7 PDK ( with sports chrono) feels at least 90% same. |
04-29-2014, 07:00 PM | #19 |
Rep 1,054
But a 1M was about 35k more than a 135i for basically the same bump in performance between a Cayman and Cayman S? *flame suit on!*
05-01-2014, 11:11 PM | #20 | |
Rep 4,848
Many BMW owners moving to P cars at the moment - interesting.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
05-09-2014, 04:05 PM | #21 | |
19
Rep 313
...but the 135i doesn't feel 90% same as 1M to me : |
