06-03-2014, 07:48 PM | #1 |
Rep 939
QUESTION! Parts failing,warranty and faults
Hey guys its seem like there is a whole list of things my car/ our cars (135i E82)
were parts has been failing which has been cover under waranty or out of our own pockets. Just a question air to see what is the listing like. Feel free to add your list. Passenger out side window door trim/ trim bowing up Creaking folding side mirror/broken washes Car serging/ ecu programing HPFP/failing Coil pack /failing Alternator cable / broken Oil filter gasket/ leaking Charge Pipe /split Coolant Tank/ leaking |
06-03-2014, 08:04 PM | #2 |
Rep 491
mines a convertible.. add to the list;
-clanging windows when they all come up -dash trim popping up -steering wheel flaking -roof getting stuck half way through coming off (reported this a number of times and was assured nothing wrong with it. I now have to give it a lil push as it goes back) -wastegate rattle -dash top storage compartment is hard to open -seat handle (up top to make the seat fold) has popped out -the amount of heat in the foot well (esp in summer, have to have the AC on at feet whilst cruising with the top down) and these are just off the top of my for now. |
06-03-2014, 08:25 PM | #3 | |
162
Rep 1,460
Thermostat Wheel bearing front and rear LPFP Head gasket Fuel injectors High stop light cracking Coolant by pass plastic hose failure Vac hose / accumulator failure Front brake caliper piston / seal failure Turbo failure Steptronic megatronics sleeve oil leak But don't be put off by a few issues no car is perfect, Personally i think that these cars a dam good thing, great bang for your buck and cheap to repair. Just try and run a Evo, WRX, or a GTR then you WILL be broke |
06-03-2014, 08:25 PM | #4 | |
Rep 2,682
When I first got mine I had an issue where the roof would get stuck and I had to open and close it half it again for it to work. Eventually I heard a loud snapping noise and it kind of started to work properly. Took it in to BMW and they said nothing was wrong. Also had the windows rattle a lot. Every time I would go over a bump they would rattle against each other if the roof was off. They ended up taking apart the car to retighten some window mechanism or whatever but tried to blame a driver side accident when it was a passenger side window issue. Fuckers... Then I had a rattling inside the roof. Turned out to be a loose clip. I just pulled it back into place. Lastly, if I don't use the roof for a bit it will get stuck and it needs a little push. Probably just needs to lubricant somewhere I reckon. But yeah Thony, you got bad luck man...
06-03-2014, 08:37 PM | #5 | ||
Rep 2,682
06-03-2014, 08:43 PM | #6 |
Rep 839
Injectors
Cracked rocker cover (above cylinder 4). Nothing like a sh#t ton of oil filling up your plug/injectors holes and leaking into the engine fouling everything up.
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec |
06-03-2014, 11:52 PM | #8 |
Rep 939
06-04-2014, 12:31 AM | #9 | |
N55 Commando
55
Rep 797
But local dealership do not have the parts yet. |
06-04-2014, 12:48 AM | #10 |
Rep 939
06-04-2014, 01:22 AM | #11 |
Rep 939
thanks Eddie135 just called BMW AUSTRALIA and fould my car was effected with the VANOS recall. Called my dealer up and told him about it, now he sees it after i told him about it 2 months ago.
Question, are you still driving around in your car? when did you first recieve the recall notice? |
06-04-2014, 02:00 AM | #12 |
162
Rep 1,460
06-04-2014, 02:45 AM | #13 |
Rep 472
Drives: Volvo S60 R-Design Polestar
These issues are confirming my decision to keep the car stock. Once you start cranking more power out of an engine, stuff that may have gone wrong starts happening sooner.
06-04-2014, 03:34 AM | #16 |
Rep 226
All cars have issues. No design is ever perfect. That's why you need to find yourself a good workshop.
To add to the list: - Auto dip mechanism in passenger side mirror stopped working on mine and was replaced under warranty. - Battery cable recall done last year |
06-04-2014, 05:16 AM | #17 |
Rep 758
Mines 5.5years and 55k.
The only fault of note and I'm not sure it's a fault is that the steering is very noisy/grindy at parking speeds. The cranky windows happen sometimes, but not often. Oh and the steering wheel is flaking a little. Overall nothing much, the steering concerns me ever so slightly. B |
06-04-2014, 08:30 AM | #18 |
Rep 939
06-04-2014, 05:22 PM | #19 | |
N55 Commando
55
Rep 797
I got the recall last month from my local dealer. I still drive as per normal, got PPK2 in my car. When it's cold I go easy and gentle, once it hits the normal temperature I will drive it like it was STOLEN, WOT all the way |
06-04-2014, 05:24 PM | #20 |
N55 Commando
55
Rep 797
No doubt our 135's is a good car but the reliability of it really worries me.
I have done numerous warranty claim on my car, my claim fills out one full A4 page. I plan to keep the car for good also. |
06-04-2014, 06:44 PM | #21 | |
Rep 2,682
06-04-2014, 06:51 PM | #22 | ||
Rep 939
I agree there is no design that is 100% perfect and free from failure. All moving parts and sits in differents cliamate will have a effect. I just wanted to gauge the range of things that could potentially fail in the future. I LOVE MY 135i regardless! Quote:
unless i get married and have 8 kids i may need a mini bus! lol Im abit nervous when the dealer told me thats the first that they ever heard of the VANOS recall (BULLSHIT) and my car poitentially be the first guinea pig test! Be sure to ask to see all the bolts they have remove from your car as a peace of mind! |
