06-14-2014, 08:51 AM | #1 |
BimmerPost Supporting Vendor
125
Rep 698
changing diff mounts, guibo and center support bearing.
getting some clunking and wanted to make sure i hit up any possible weak point. am i missing anything? thank you
2018 F80 ZCP
06-14-2014, 10:47 AM | #2 |
5252
Rep 10,626
How many miles do you have that you have worn out a guibo and CSB? I understand the diff mounts are a weak point, but had not read the rest were problems.
06-14-2014, 10:57 AM | #3 |
125
Rep 698
i have 60k its a 6 speed. you have given me some advice already!!! maybe it is just the diff mounts. should i attack just that first or change everything out?
2018 F80 ZCP
06-14-2014, 11:20 AM | #4 |
Rep 816
What you should do is inspect said items and see if they actually need replacing. Try and at least localize the sound. Each of those items make a noise under different circumstances.
06-14-2014, 06:29 PM | #5 |
5252
Rep 10,626
If you are getting clunking, something is wrong. The only things I have read about that have gone are motor mounts and diff mounts, with diff mounts being the more likely. Check the diff mount bolts.
06-14-2014, 11:39 PM | #7 |
3387
Rep 7,542
When do you get the clunking?
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
06-15-2014, 06:44 AM | #9 |
5252
Rep 10,626
I assumed the OP did not have a clunking and then a clunking began. If so, I would look for a problem. If the car has clunked from Day One, that would be different.
06-15-2014, 09:57 AM | #10 |
125
Rep 698
i can hear the clunk under load when shifting at high rpm. in my e46 m3 i changed out the center support bearing and guibo and it went away. i just thought it was the same for the e90 m3.
2018 F80 ZCP
