6.7KVIEWS
52REPLIES
3APPRECIATES
17ACTIVE PEOPLE
05-16-2026LAST POST
02-21-2026
It’s very technically easy to do. I can probably do it in 4-5 hours but the problem is a shop will charge you labor by the hour at $180-$250 per hour which will make it too expensive.
02-23-2026
For the most part, wiring harnesses on a modern BMW do not tend to have one size fits all, and on a less optioned vehicle, have a lot of empty plugs hanging out there that would allow you to just plug in options. Each new BMW will have an internal list of delivered hardware options, and when an update is made, tend to leave those functions intact (i.e., not overwrite them back to the as delivered functionality). A dealer is unlikely to be willing to update that VO coding, and on the LCI as they appear to match it up with the VIN as delivered from the factory, you may have trouble getting someone to be able to change the coding.
02-23-2026
Honestly I'm willing to pay up. It's a feature my wife specifically finds handy as she struggles in tight spaces with a car this large. Maybe I will ask some local independent shops here their thoughts here in Dallas.
02-23-2026
You already have a reversing camera correct? they would just need to add 1 camera in each mirror (which is easy to do) and 1 camera in the front bumper then run the wires to the left driver footwell and install the module there. Access to the left driver footwell takes 5 minutes and access to each mirror takes 20 minutes. Gonna have to run the wire harness through the door which is gonna require them to take the door trim off and that does take a bit of time. Then have to take off the front bumper (that’s probably about 30 mins). Then they have to run wires from engine bay to the left driver footwell well. Taking off the bumper and running wires from engine bay is what’s going to take the most time. You are pre-LCI so coding shouldn’t be an issue.
02-23-2026
The rear camera is different.
It is "wide angle" compared to the standard reversing camera.
Total installation time was just under 5 hours which included the coding.
02-23-2026
Thanks - but fundamentally the same mirror housing would work? Same goes for bumper, assuming they'll just find a spot where they can mount said camera versus having to do something custom to the bumper.
02-23-2026
I think the kit on alibaba comes with housing for mirror and front bumper camera and wide camera replacement for rear
02-23-2026
With the full camera package, note there is a camera on each front fender looking sideways so you can view the traffic should you be say peaking out with an obstructed view like can happen at an intersection or parking lot when you poke your nose out. It can be especially helpful in an old city where the buildings run almost up to the street with a narrow or non-existent sidewalk.
02-23-2026
I have the full package and just checked mine definitely does not have cameras on the fenders.
02-23-2026
Does the coding get wiped out or over-ridden after a software update?
02-23-2026
They are on my 2021...can't say about other model years, or option packages. If someone insists, I could take a picture, but it would likely be nearer the end of this week, as I have no plans to go anywhere, and can't get a good shot in the garage.
02-23-2026
No had two updates since and all coding is ok.
As previously said, the coding also enables Drive Recorder,Remote 3d View and Remote Parking.
On my LCI there is only 1 front "wide angle" camera, which like the rear camera give great panoramic views when emerging from a tight spot.
02-25-2026
Thank you. Okay, now the elephant in the room: how trustworthy are these kits that are clearly not OEM parts? If they are generally reliable and function as intended, then I am good to go. Really wish I had a shop like gentleman in the UK who specifically stated they use OEM parts and do the whole installation as one package.
02-25-2026
The alibaba kits are original BMW. Some parts are brand new and some parts are used/refurbished. I don’t have experience with 360 camera kits or this specific vendor but I got a 5AU driving assistant professional retrofit kit from alibaba/ChinA. All original bmw and all clean. Everything worked. The alternative is to find the required part numbers for the 4 cameras, module, mirror and front bumper housing on realoem and buy them used on eBay then buy the wire harness separately from alibaba/aliexpress.
02-25-2026
Same, have every option on my ‘22 and there are no cameras on the fenders. Just one in the front grill, one in each side mirror, and the one rear camera. When pulling out of a blind spot and I switch to the front panoramic wide view it’s only using the camera in the grill.
02-26-2026
My 21 has every option but the surround view, so I picked up one one of these kits and the kit I received has OEM cameras and module. Wiring harnesses are obviously custom but seem to be good quality. Now I just need to find the time to install all this. Definitely not a plug and play deal
02-26-2026
Which kit did you buy? The alibaba one?
02-27-2026
It was from another member on this forum, but it shipped from china so I can only assume the one on alibaba is the same kit.
03-04-2026
Mikhalidis wrote
https://www.alibaba.com/x/B1Xuxc?ck=pdp
Here is the kit for $800 if you are a DIYer. I can get you ISTA wiring diagrams to help with installing but you have to find somebody to code it which can be done remotely for $150.
Hi there- I actually purchased the Emtronika 5DN (Parking Professional Plus) Retrofit for G05. My installer ran into some trouble and couldnt complete it because of the wiring harness/ cables issue. Would you mind sharing the ISTA wiring Diagram? Have a 2023 G05, pre-LCI
Here’s link to Emtronika, and I emailed them directly with my VIN and they confirmed compatibility.
https://emtronika.com/en/backup-cameras/470-icam-bmw-surround-360-camera-retrofit-set-kit-5dn-x5-g05-g06-g20-g30-g32-lci.html
03-05-2026
Here you go drsubzi's user avatardrsubzi . let me know if I can be of any help. I retrofit driving assistant professional in mine. can't imagine this being more difficult.
03-06-2026
This is honestly incredible, thank you! Mikhalidis's user avatarMikhalidis I notice you’re in South Florida, as am I. Do you have any recommendations for a good installer for something like this? I don’t have PMs activated (yet) but if you’re open to sharing, I would drop my email here for more info.
03-06-2026
Prestige Auto Solutions. The guys there are pretty good. Owner used to be foreman at Braman I think. Prices are reasonable.
Not so Flo and not a shop but you can see if SaNGRia's user avatarSaNGRia would be willing to do this.
