225.1KVIEWS
429REPLIES
94APPRECIATES
95ACTIVE PEOPLE
05-11-2026LAST POST
10-24-2021
Almaretto wrote
Engine should be running to read out car. It does not affect mapping, but needed to provide power/wakeup signal. What error are you seeing?
I wish I had saved the log file. It was something to the affect that the file didn't exist. The error was in the esys log. I thought it might be a pzdatafile issue, but it seems to be a later version than what is needed for the istep version.
As I type this I might be a pzdata issue. I thought the file I downloaded was 4.31.31, but this may not be correct. The zip file is listed as 4.28.21, which would not be correct for the 3.21.55 istep. I'll download the latest PZdata and see if it fixes things. Egg on face :bonk:
10-24-2021
Not found [c012] means time to update psdzdata.
10-29-2021
Unless you have log set to auto-delete, it should be available in data folder.
12-18-2021
electric2021 wrote
Question - I bought esysx back in spring when it supported sw version 03/2021 and coded some features. If I update my car to 07/2021, will I be able to still code the same feature or mappings will be different? If so, should I upgrade my esysx? And can esysx be only updated via paying them for a license update? Thanks!
So, the same question again - my car was updated to 11/2021 and I lost automatic aSLA. Is there a chance I can use my old esysx with older pzdata to code this back or everything is lost (I cannot even do an update!!!! Esysx moved to cloud and they do not allow coding yet. )
12-18-2021
If you were able to code previously then you should still be able to as the mappings for asla has not changed. Newer values will not be mapped correctly but older ones should be fine. Also you can use cheat sheet to code ASLA.
12-18-2021
There is newer mapping in Esysplus, but unlikely to have issues, compared to Launcher Pro with 2018 mapping.
12-19-2021
Thanks for posting the info, does anyone know if this will work well with G06?
12-19-2021
Thanks! Will try tomorrow
12-20-2021
Not clear what specific "this" is referring to on an 18 page thread, but G06 and G05 are essentially the same electronics platform, so anything referring to G05 applies to G06. There are more variations between software versions and car build dates than there is between G05 and G06.
12-20-2021
So sorry for not being more specific, but i meant the referenced file (Github) in the original post.
And thanks for the answer. I will give it a go and check.
12-21-2021
Thanks. Just did coding today and aSLA + TLA work again :)
12-21-2021
Anybody tried to code aSLA for US-based cars?
12-21-2021
I have this coded on MY2019 G05, and works well. I coded this using EsysX. My iLevel is at 11/2021.30.
I also have TLA, but it does not work as intended in the US. I think that it's because of the placement of traffic lights in the US. In Europe they are placed on the side of the roads before the intersection, and in the US they are on the opposite side of the road and towards the middle of the intersection. Just my opinion tho.
12-22-2021
TLA is working, but not consistent, is it what you have? Does it stop on the red light automatically?
12-22-2021
It works, but no the way it's intended. It stops in the middle of the intersection, which makes it very dangerous. The other features work such as the light recognition, and also the reminder when the light turns green.
01-11-2022
Hello I guys, im quite new with coding.. ;)
During the weekend I tried to do some first codings to my G05
I have:
E-Sys 3.27.1
E-Sys Launcher PRO V2.8.2.162
PSdZData Lite 4.33.11
My G05 is 06.2020
I succesfully coded ASS tl last position
Ive tried to code M/Alpina dash, M Logo but without success
I was able to read ECU, read coding data but than im not able to find for example: GLOBAL_LAYOUT_VARIANTE to change dash to M
I can see some folders with numbers and than only folders without name like on attached picture:
01-11-2022
I have:
E-Sys 3.27.1
My G05 is 06.2020
Your E Sys set up is too old & out of date for G series you need to use Esysx when available or get an adaptor for the E Net cable to phone and use Bimmercode it can do most things bar aSLA,TLA & anti Dazzle. Download the free App & have a look at the X5 settings it will tell you what it can do. I have attached a list of ECU's that BC can access. You can use expert mode to easily change codes as you would do when FDL coding in Esys
01-12-2022
Is it only Esys to old ot other (Launcher, PSdZData are ok?) Which version should I use and where to find it?
01-12-2022
ESys 3.34 or greater to do FA editing & VO coding only. PszData must be same release as your current iLevel or younger PM Shawn Sheridan for links to the latest ver of ESys & PszData. He also has a contact for Launcher Pro 3.7x which does NOT have the latest NCD mappings but you can use it to code aSLA only in conjunction with BimmerCode that has the latest mappings for the BDC & MGU_HU ECU's. Launcher Pro 3.7x is missing or does not have the correct FDL mapping for TLA & other MY21 features in the SAS3, BDC & MGU_HU ECU's.
01-14-2022
I just finished coding with Esys plus latest mapping no issues worked fine ,tried with EsysX already on latest mapping having issues:(
01-20-2022
Hi, guys! I have changed bronze to pink, but B&W speakers still has bronze lighting. Does anybody know how to fix it and maybe cheat code for B&W speakers
03-21-2022
whats needed to be coded for:
- to have angel eyes at 100% with headlights?
- delete sidemarkers?
- automatic braking when reversing too close to something?
- automatic braking when coming close to something when going forward?
2019 G05 xDrive50i
have BT OBDII (MX+) with Bimmercode
ordered esys cable and have all software downloaded but no clue how to use it as of yet, though, but want some instructions ahead of time :)
any help would be appreciated
