225KVIEWS
429REPLIES
94APPRECIATES
95ACTIVE PEOPLE
05-11-2026LAST POST
03-21-2022
elite-fusion wrote
whats needed to be coded for:
- to have angel eyes at 100% with headlights?
- delete sidemarkers?
- automatic braking when reversing too close to something?
- automatic braking when coming close to something when going forward?
2019 G05 xDrive50i
have BT OBDII (MX+) with Bimmercode
ordered esys cable and have all software downloaded but no clue how to use it as of yet, though, but want some instructions ahead of time :)
any help would be appreciated
Im trying to remember if one of the parking features requires more than base hardware as far as sensors go. Most of the advance features depend on the hardware included in the driving assistant and parking assistant packages. I used esysx so unsure about bimmercode
03-21-2022
Where do i go to check if it can be done?
Can the things I posted last be done with esys? If so, I will have that up by midweek this week.
03-21-2022
I believe this thread has a link to an excel sheet that explains which computer and line item can be coded for the G05. Some things are similar cross platform, so it's helpful to look at other G models to see if there are similarities.
03-21-2022
Thank you :)
03-21-2022
elite-fusion wrote
Thank you :)
I added the PDC line item to my previous post.
03-21-2022
Thank you so much!
03-21-2022
Nice. Ty
03-21-2022
Bambazonke wrote
pepe1234 wrote
Hello I guys, im quite new with coding.. ;)
During the weekend I tried to do some first codings to my G05
I have:
E-Sys 3.27.1
E-Sys Launcher PRO V2.8.2.162
PSdZData Lite 4.33.11
My G05 is 06.2020
I succesfully coded ASS tl last position
Ive tried to code M/Alpina dash, M Logo but without success
I was able to read ECU, read coding data but than im not able to find for example: GLOBAL_LAYOUT_VARIANTE to change dash to M
I can see some folders with numbers and than only folders without name like on attached picture:
Your E Sys set up is too old & out of date for G series you need to use Esysx when available or get an adaptor for the E Net cable to phone and use Bimmercode it can do most things bar aSLA,TLA & anti Dazzle. Download the free App & have a look at the X5 settings it will tell you what it can do. I have attached a list of ECU's that BC can access. You can use expert mode to easily change codes as you would do when FDL coding in Esys
What's aSLA,TLA ???
03-23-2022
Resjudicata wrote
What's aSLA,TLA ???
I think it's the traffic light assist and lane change assist. You'll need some of the advanced hardware packages like DAP to use these features. Be careful if your coding the more advanced self driving features.
03-23-2022
aSLA is Automatic Speed Limit Assistant.
03-23-2022
Thank you I think I was able to code that in my base model. It will change speed based upon signs. I don't have the ability for it to slow through traffic circles. That might be the etja though. I stopped looking into the more advanced features when I realized my x5 lacked most of the advanced hardware. I didn't make that mistake when ticking boxes on the new one :)
03-24-2022
hey Guys, do you know if there is an issue with Launcher Pro
I have Launcher Pro: v3.7.0.315, and it is not coming up.
Last I coded was in Oct'2021 when it worked fine
03-25-2022
If you have 5AU in your FA and have aSLA coded correctly the car will slow down for bends traffic circles & T junctions on the route if you have Driver Assist Professional (DAP) active AND navigating an actual route.
If you take the car to the next stage and have UCC (Urban Cruise Control) coded in your SAS3 ECU the car will slow down for the above road features WITHOUT navigation active. It will also slow down at a known junction if the road is in the map database using your indicators about a 100m beforehand but not at the driveway to your house or at a fuel station entrance. You do not need Driver Assist Plus (Etja)
03-25-2022
Yes after a Windows 10 update fortunately my version still works but I have to close all other programs down disconnect from the Internet and then boot up LP. If you have the same version or bought from the same eBay source, you will see the date & time change to some day in May 2020. You can still do FDL editing and updates to the car but do not run any other programs at the same time.
I use Bimmercode in expert mode where possible as it has the latest mappings and LP where BC has no mappings for that particular ECU eg SAS3 ECU
03-28-2022
2019 G05 xDrive50i
For the first two, it is and will unlikely be posted anywhere.
For automatic breaking, you require FSC code and correct coding.
03-31-2022
@Almaretto Have you seen any coding specifically relating to eV and PHEV battery coding?
03-31-2022
I have seen some that were carryovers from i3. Have not tested any on G05.
04-07-2022
homerrr wrote
question on speedlock settings; I have coded this:
Ability to view text messages, control messages and Widget setup screen whilest in motion (up to 63km/hr only), the following codes are in (3E53 - HU_MGU)
SPEEDLOCK_SPEEDVALUE_MIN - set wrete value to 1F
SPEEDLOCK_SPEEDVALUE_MAX - set wrete value to 3F
SERVICES_MESSAGES_SPEEDLOC_CONDITION - set to none
SPEEDLOCK_CAR_STANDSTILL - set to none
SPEEDLOCK_TEXT_LENGTH - set to whole_text
works fine, but it conflicts with VIM regarding the settings in SPEEDLOCK_SPEEDVALUE_MAX and MIN, where VIM needs that set at none and werte 00, if I am not mistaken. so, do I have to choose between one or the other or is there a way?
Is it possible to raise the max speed of 63 Km/hr? Lets say to 100 or 120 Km/hr?
04-07-2022
Not via werte values. The storage info shows bitmask details which limit accepted values.
04-08-2022
Oké, thanks for the explanation.
04-09-2022
:thumbsup:
02-21-2023
Does anyone have the latest cheat sheet for G05?
