Ninefourteener wroteThank you for the credit.Dr. Jekyll wroteI bought my BBM drop links from someone else. They weren't "used", but they didn't come with any instructions at all. I actually obtained a copy of RGSport's instructions, reviewed, analyzed, etc.... and then incorporated some changes.I sure as heck wish someone told me to disconnect the electrical sensors before replacing! I didn't and my suspension maxed out on high until it reset about 20 mins later. It was pretty wild. I drove it a bit like a 2 wheeler and nothing but after parking it for awhile and coming back to it I was okay. Good tips here for sure, too bad I couldn't read German and after google translating the instructions I still saw no mention. Good looking out bud.
68.2KVIEWS
152REPLIES
120APPRECIATES
57ACTIVE PEOPLE
05-09-2026LAST POST
Ninefourteener wroteDo you have to drive a little immediately after installing the front links, or can you just install all four corners then drive for auto-leveling?Step 2..... remove links.
Adjust new links 3mm longer for a 1/2 inch FRONT drop.
Install new front links.
Drive about 150 yards so the suspension adjusts itself.
bforbrian wroteNo, you can do all 4 corners at a time. I was more focused on "get the front done first, then focus on the rear".... but it isn't necessary to do it that way.Do you have to drive a little immediately after installing the front links, or can you just install all four corners then drive for auto-leveling?
It is necessary, to make sure that the electrical connections are disconnected while doing any changes, adjustments, etc. Don't plug the connectors back in until the links are set.
If they need to be adjusted, disconnect before making any adjustments.
Masterplan wroteWon't be a problem. My new wheels don't have spacers, but the offset is equivalent to running stock 21s or 22s..... with a 35mm and 40mm spacer.Anyone done this with spacers on stock 22"s?
Which...... no one should do btw... lol
I was running 15 and 20mm spacers on my 21s, and even with my new 22s, no rubbing over bumps, full-back turn... nada.
My drop however, is moderate. I may go a few mm lower, but I'm getting a feel for the new wheels & tires first.
Ninefourteener wroteThat looks awesome. Congratulations.Masterplan wroteWon't be a problem. My new wheels don't have spacers, but the offset is equivalent to running stock 21s or 22s..... with a 35mm and 40mm spacer.Anyone done this with spacers on stock 22"s?
Are there any differences between the BBM and RGSport links?
Reading this thread it looks like configuration is specific to link set?
Masterplan wroteDifferences? Not really. I suppose they look a bit different, but they accomplish the exact same thing. I believe RGSports links are more "metal" while BBM links are more "plastic".... but they don't provide any "structural" support... so I don't suspect it really matters either way.That looks awesome. Congratulations.
My measurements, were based on the overall length of the links themselves, whereas 4GSport's directions apply to only their specific product.
My measurements, will work on any aftermarket droplink set.
However, I would recommend RGSport's links more than the BBM.... if for no other reason than their quality instructions. BBM instructions are in German, and they have no customer support whatsoever.
Masterplan wroteYes I'm running 15/25 with lowering links no problem purchased both fromAnyone done this with spacers on stock 22"s?
** IMPORTANT: Recommended to code the car's default start at "Eco Individual", "Comfort Individual", or "Sport Individual" where you can set the suspension to start at Sport, otherwise you will go too low when you go into Sport mode with the link adjusted too low at Comfort mode.
Is this just for installation or for long term?
From RG Sport website.
heeblet wroteI'm not sure what all that means, but it does not sound correct.Pardon me if I sound like an idiot.. What does this mean exactly in other terms?
When you install droplinks, your car will be X amount lower in EVERY setting. You can set it to be a few mm lower, or you can set it to be 2 inches lower.... and everything inbetween.
Whatever you choose (let's say you go exactly 1 inch lower).... then all 5 settings will be exactly 1 inch lower.
It doesn't really matter if you code your car to start in Sport, or just maintain the factory Comfort setting. All 5 settings will be 1 inch lower.
If the setting is too low.... and your suspension bottoms out (you'll know, trust me. The car will ride horribly).... then you can just raise them up a bit. NBD.
I "think" what RG is saying, is that if you "dump" the suspension so that it rides very low in Comfort mode.... then if you ever drop it into Sport, it will bottom out the suspension.
Just make sure that the "lowest" you want to go... is set in sport mode... so your car won't go lower than expected.
heeblet wroteI tried to make that notation as short as possible.Pardon me if I sound like an idiot.. What does this mean exactly in other terms?
But, the long version is this.
Whenever you put your car into Sport driving mode, it will lower about 0.75" than Comfort.
So, if you use the lowering link to lower 1.5" under comfort driving mode, when you switch to sport driving mode, it will go to 2.25" drop.
Which at that amount, you will rub and may lock up the rear tire and cause damage or even accident.
What I noticed with my 2021, Comfort mode remembers last driving height. It didn't reset to middle.
Only if I switched driving mode, that's when it will reset to middle.
r33_RGSport wrotehey quick question. how is your lowering link with road salt?I tried to make that notation as short as possible.
I trying to order but want to see if it gets rust due to road salt or not.
Thanks.
bimmerwerks wroteIt has zinc coating on it.hey quick question. how is your lowering link with road salt?
Thanks.
If you want to be safer, once you are set on the height, you can spray them with paint or plasti-dip to create some more coating on it.
r33_RGSport wrotecool im just going to order it todayIt has zinc coating on it.
Gtz1wickedest wroteHow do the rears look with 25mm have you go any more shots? From this pic it looks awesome! Just wondering wether to go 20's or 25's on the rear!Masterplan wroteYes I'm running 15/25 with lowering links no problem purchased both fromAnyone done this with spacers on stock 22"s?r33_RGSport
Mr.Pringle wroteI ran 15 and 20mm spacers on my stock 21s, and it was fine.How do the rears look with 25mm have you go any more shots? From this pic it looks awesome! Just wondering wether to go 20's or 25's on the rear!
My 22s are considerably wider and more aggressive, and are the "equivalent" of running 35mm and 40mm spacers.
PLEASE do not attempt to actually run 35 and 40mm spacers - LOL
In both cases... I like the look.
Olekiller wroteOh hell no! The installation takes all of 30 mins. and requires zero programming.Hey I ordered lowering links at a shop called eumd that did my powder coating for my wheels. Anyways they are charging me $300 for installation saying they have to program the car after installing. Like I know that's not correct and needs no programming. But I just want to confirm from you
Olekiller wroteInstallation of the tires back on to the wheels?? Because that at least I can understand, because it requires mounting balancing, etc. $300 is quite expensive for mounting and balancing. I usually pay $80-$100.Hey I ordered lowering links at a shop called eumd that did my powder coating for my wheels. Anyways they are charging me $300 for installation saying they have to program the car after installing. Like I know that's not correct and needs no programming. But I just want to confirm from you
For "Installing the wheels on to the car, and coding"??? No... that is BS.
The car will automatically recognize the TPM sensors. You don't need to code anything.
R3v1v3 wroteReally shouldn’t be that hard. I was able to simply pry / pop them right off with no issue at all.Does anyone have any know of an easy way to pop out the original links? I tried it with the heat gun, and also the "socket trick" but none of them worked and I ended up breaking the ball socket piece that connects the link to the car. Please help, as I'm almost tempted to not go through with it anymore. Thanks in advance!
