121KVIEWS
21 hours agoLAST POST
02-19-2022
Aiki7 wrote
Here's the M spoiler on a 22 45e in Arctic Grey
Looks awesome!
02-21-2022
wrussell1992 wrote
jheffren wrote
wrussell1992 wrote
I also have one coming from RG - will share some pics once its installed (Artic Grey m50i)
Do you have any photos you'd be willing to share? I'm considering this and also have arctic grey! Thanks!
Here's a few in arctic grey. RG did a fantastic job. Super pleased
Off topic - what ski rack setup is that? I am looking for one for my g05 x40i
03-21-2022
Looks brilliant!
03-24-2022
KrisV wrote
I have an X5M spoiler in alpine white I'm looking to sell. PM if interested
PM'ed
04-13-2022
IND had the roof spoiler and mirrors shipped over in less than a week! Packaging was unreal; installed mirror covers and roof spoiler in under 15min.
Makes the 45e look perfect!
04-13-2022
Looks awesome!
05-14-2022
Posted on a different thread, but thought I’d drop the question here as well: anyone put the black M-style rear spoiler on a white X5?
05-14-2022
Wtfitzvi wrote
Picked up my X5M spoiler today from the paint shop.
Very easy to install… just remove the 4 rubber caps, unscrew the 4 torx screws, close trunk, pull back on the oem spoiler, swap clips and install in the reverse order.
Trying to follow your directions:
1) remove 4 rubber caps - yes, the 4 upper ones, not the 2 lower/outer ones for the gloss black side supports.
2) unscrew 4 torx screws - yes.
3) pull back on oem spolier - pull how? Beyond flexing it won't budge for me when prying with plastic pry tools. I don't see a way to put it back without using some tools...
05-15-2022
Just to be clear... the spoiler does not pry off like a hinged lid. If you're standing at the rear of the vehicle, the spoiler will slide back toward you. Refer to the picture in this post https://g05.bimmerpost.com/forums/showpost.php?p=27149828&postcount=16. You've unscrewed the torx screws from the four "nuts" across the top. The two clips you need to get to release are the white ones pointing toward the top of the picture. Notice their orientation.
Get the tips of your fingers on one hand inside the gap between the spoiler and the roof. Put your other hand on the other side of the spoiler near the brake light as you try pulling toward you. These clips hold on surprisingly tight, so it may take some force to release them. Go back and forth on either side as you try to work them loose. Always have both hands on the spoiler as you pull because it might come flying off with a loud pop and you have to catch it as you're stumbling backwards off balance. :cool:
05-16-2022
Thanks dormouse's user avatardormouse that was very helpful! We ended up using some rubber coated hooks w/straps (from a trunk mounted bike rack) to pull it, along with the hand in the gap technique.
Installed the new one from IND and very happy with the new look!
09-21-2022
njnets21 wrote
a few shots of this spoiler in lime rock grey
Love this color. Clean combination
09-22-2022
I keep seeing a back and forth conversation on shaving or not shaving.
Someone needs to post a picture on what and where they have shaved or put double sided tape.
09-22-2022
double sided tape ontop of 3rd taillight
I did not even look at OE to see if there was a gap
Took delivery of car.....swap when it was home.
Noticed the gap and ended up removing to put tape/reinstall.
It's minor. About 3/16" gap just the length of the taillight
10-22-2022
Ultimately from a water seepage/ electronics standpoint—is it fine to leave the gap?
10-22-2022
Yes, you'll be fine.
10-22-2022
is it true that you can only choose either the x5m spoiler or the m performance flow through spoiler (51-19-2-464-331), not both?
10-22-2022
Arctic Gray Metallic on Xdrive40i
10-22-2022
Makes a big difference, after you get it installed!
10-23-2022
sick rims!!!
11-18-2022
Finally got one installed. Huge difference, huge is understatement actually. Had to grind the tabs off for the spoiler to sit properly above the break light with no hap.
12-15-2022
has anyone seen a gloss black X5M spoiler installed on a mineral white body by chance? would love to know what it looks like..
12-15-2022
color scheme is similar to the M Performance flow-through spoiler on a white X5. can search the forum for the thread. I believe there’s a couple white vehicles posted there
