TurtleBoy wroteYou are comical.No, not at all. The issue is that you can't enable the full feature Anti-Dazzle using bimmercode since VO needs to be used and there are ECUs that Bimmercode does not have access to. You were insisting that you did but finally after overwhelming evidence and various people telling you that you were wrong did you give up.
I never insisted that BC had access to KAFAS, what I insisted was that you can get all the features as seen in the videos with no light bleed (as you kept insisting).
Such is life. The posts are evidence of your foolishness.
