120.8KVIEWS
20 hours agoLAST POST
12-05-2020
Hello everyone, i have g05 m sport 40i and i was wondering if it is possible to get a roof spoiler exactly like on X5M? I dont like the design of those ebay kits. Please give links and share photos if you have done. An image attached to this post, provided by the poster
12-05-2020
BMW OEM X5M REAR SPOILER RETROFIT KIT - BMW (F95X5MSPOILERRETROFIT)
Part Number: F95X5MSPOILERRETROFIT
Description: Kit includes a primed rear spoiler that can be painted at your local body shop. Includes: 51-62-8-083-919 × 1 , 51-77-7-171-002 × 5
12-25-2020
Please let us know when you find out
01-06-2021
Available from where?
01-06-2021
Just did one for local customer. :)
01-07-2021
Was it a pretty straight forward installation? Just unbolt/unscrew the standard rear roof piece and bolt in the M version rear visor? Thanks...
01-08-2021
Yeap. Exactly. :)
01-08-2021
Looks pretty good. Rough cost?
01-09-2021
You need to check your local supplier.
Price can be different between US market and your Australian market.
01-21-2021
I've just fitted it to mine and think it looks good
01-21-2021
Thanks for the pics. Much nicer than the standard spoiler. Where did you buy it and how much did it cost? Did you fit it yourself?
Cheers
01-22-2021
Looks great, look forward to change to it as well.
I can see you have carbon diffuser as well, look great :thumsup:
01-22-2021
r33_RGSport wrote
Yeap. Exactly. :)
Look great I've also ordered one. Was there any clips to remove?
01-22-2021
Yes, 2 clips, 1 on each side.
I'll take pictures when I get mine back from the paintshop.
01-23-2021
Attached is the underside of the factory installed spoiler that comes on the X5M. The two white clips are on each side just about midway down. And boy did they hold on pretty well for dear life. Be prepared for a loud pop when each one lets go. I thought I broke the spoiler when I heard it.
01-23-2021
Cheers
I bought it from Williams bmw Liverpool mate then had it painted and fitted it myself
01-23-2021
Sorry to use you picture but did you have to trim the 3 tabs that stick up that I have Circled? Mine wouldn't set right at all on top of the 3rd Brake light without trimming them down.
01-23-2021
Why did you remove it from your X5M out of interest?
01-24-2021
Then you were installing it incorrectly. Those 3 tabs need to connect to the proper locations in the lower part of the spoiler near the third brake light. Keeps away the squeaks and rattles.
01-27-2021
I contacted BMWPARTPROS.COM but they have yet to get back to me to confirm if the part will fit.. Although after seeing your pics, it clearly is a direct bolt on.
I just need to figure out where to buy from?
01-27-2021
For the UK guy's on here, I contacted BMW in Colchester and they quoted £820 including vat; that also includes fitting. The Spoiler comes in Black so it will cost extra if you require it to be painted. According to the BMW parts guy it's only a 25min job, therefore you wont save much if you fit it yourself (approx £70+).
So all in all quite an expensive mod (well, in the UK it is).
